dyno numbers; stock d16z6 50 trim 10psi 246whp/223wtq
i decided to take my civic to carls accurate automotive in logan utah today to do a couple dyno runs. the results are not what i expected. i was expecting 200-210 at the most. they seem really high for the given setup but im sure the weather correction factor has a lot to do with it. runs were done on a mustang dyno, also done in 3rd gear. it was about 20* degrees outside and the shop doors were wide open and a huge cooling fan was blowing against the car. total timing at 10psi is 20* with no detonation and afr was at 12-12.5
246hp/223tq, 10psi, 91 octane
stock d16z6 (unknown miles)
ebay intercooler
ebay bov
dsm 450's
stock fuel pump
ngk bkr7e
stock head studs, stock head gasket
ebay cast mani
ebay 38mm wg
ebay 50 trim (over 5k miles! still breathing lol)
open downpipe, about 1 foot in length
street tuned by me and a friend on crome
ebay intercooler
ebay bov
dsm 450's
stock fuel pump
ngk bkr7e
ebay cast mani
ebay 38mm wg
where did u get the idea the turbo is a 50 trim? have you measured the inducer and exducer of the compressor wheel?
none the less great numbers for such low psi.
i am curious if you have a fuel pressure gauge? im blown away the stock fuel pump can keep up! good job.
PS, your brake fluid is low
good numbers man! alot of whp for 10psi but its mostly due to the timing. get a fuel pump in it, I have dsm's and made 314whp with room to grow.
apparently the chinese are bad at math...
dang, i hope my number r up there too, i'm only goin 8psi tho so we'll c, i won't be setup and tuned till
late february so once i get my number, i'll let ya kno
damn those are some nice numbers.
i'm looking at going through the same setup pretty much. stock motor but with arp headstuds, dsm 450's and full exhaust 2.5", ebay "50 trim". just wondering if there is anyway you could send me your tune/.bin file? it would be a great basemap for my setup.
