TECH HELP: 93 Civic SI problems starting every after visit to the gas station
Guys, need your expert opinions on this.
I have a stock 93 civic si, i've replaced the fuel filter, spark plugs and distributor.
the car does not start when i put gas in...it seems that the fuel system loses pressure once i open up the gas tank and i have to floor the gas pedal in order for the car to start (if i'm lucky) sometimes i have to jump start the car at the gas station in order to get it going and i would have to floor the gas pedal as well...any ideas? I appreciate your help.
yeah, that's most of the time i have problems and when i park in an incline hill.
i'll take a look at that this weekend and let you guys know...any other things i should look at? do you guys think the fuel pump might be an issue as well? I never had a faulty fuel pump before in any of my other cars so i don't know if these are symptoms of it.
I had a similar problem in my 91, I thought it was my fuel pump but turned out to be fuel relay. I would test out the relay first since its free, if it checks out then proceed to fuel pump.
How do I test out the fuel relay? i'm sure i can find it on my service manual but is there a fast and easy way of testing it. thanks.
rudebwoyEg
Oct 20, 2011 09:08 PM
ken hill
Mar 27, 2008 07:10 PM
ATS*Mark
Oct 26, 2004 08:16 AM
