CR-Vtec or Boosted B20
Old Sep 5, 2002 | 08:51 AM
Bullet50's Avatar
Default CR-Vtec or Boosted B20
Question for the gang....................
I done a fair bit of reading on this over the past couple of days but still can't make up my mind. Do I go with CR-Vtec (N/A) or Boost the B20 I have. There are lots of pros and cons for both which I won't go into. I'm planning on installing rods, pistons, rings, etc. as part of the block build up. Once I put it togeather I don't ant to have to take it apart so I figure thats the first wad of cash i've got to spend. I'm interested in acheiving two things from this swap;
1. Reliability
2. Power
Thoughts anybody???????? Thanks in advance..................
B50
Old Sep 5, 2002 | 09:08 AM
Jeff C's Avatar
Default Re: CR-Vtec or Boosted B20 (Bullet50)
1. Reliability
the b20 was assembled by Honda Motor Company...therefore it was professionally engineered to be reliable
2. Power
i would say for the money you could make more power with a boosted b20 vs NA crvtec
i wish i had went boosted b20 over built b20vtec NA and the motor is not even in the car yet.
Old Sep 5, 2002 | 09:35 AM
BROOD's Avatar
Boosted B20 with built internals.
You can always graft a Vtec cyl head on at a later date if you were bored. Or staying non-Vtec might be plenty enough for you. You can make that choice later.
[Modified by SLPR, 10:36 AM 9/5/2002]
Old Sep 5, 2002 | 09:49 AM
Adam.'s Avatar
For the drag strip boost, for a road cross/autox/anythingwithturns, crvtec, it'll more responsive in the turns.
Old Sep 5, 2002 | 11:20 AM
g's integ's Avatar
Default Re: CR-Vtec or Boosted B20 (Jeff C)
1.
Good thing I got out of the lsvtec thing when i had the chance. b20nontec and boosting for me.
Old Sep 5, 2002 | 11:44 AM
W.Zero's Avatar
how about a boosted B20vtec
Old Sep 5, 2002 | 01:59 PM
bad 2 the B-ONE ej1's Avatar
Default Re: CR-Vtec or Boosted B20 (W.ZeroB18C1T)
my thoughts exactly!!!!!!!!!! for you....
Old Sep 6, 2002 | 09:36 PM
Bullet50's Avatar
Default Re: CR-Vtec or Boosted B20 (bad 2 the B-ONE ej1)
I'm thinkin' my first instinct was probably the right one. I've talked to a few people as well as using the chat lines and putting in some decent rods, pistons, etc. and booooooooooost is the way to go. If its done right 12 PSI is easy. I figure I can do a decent boost job for less than its gonna cost me to build a CR-Vtec. Besides a B20 Head is more or less a B18. Any more opinions?????????
Thanks,
B50
Old Sep 7, 2002 | 10:46 AM
shermanyang's Avatar
BOOST!! wouldn't you rather hear that quiet PPPSSSSSSSHHHHH sound over a loud *** all motor sound?!! just my opinion but i sure as hell would!! i get goose pimples all over me whenever a car rolls up to me and revvs and all i hear is the PPSSSSSSHHHHHH noise coming from the motor. you can always find a vtec head later on and slap the sucker on, so might as well go turbo and boost that baby!!
BOOST BABY BOOST!!
Old Sep 9, 2002 | 09:07 AM
Adam.'s Avatar
Default Re: CR-Vtec or Boosted B20 (shermanyang)
You can always find a turbo later and slap that sucker on, so might as well go NA and run that baby!!
[Modified by DarkKnight[DMD], 6:07 PM 9/9/2002]
Old Sep 9, 2002 | 09:51 AM
Flexmyrex's Avatar
Default Re: CR-Vtec or Boosted B20 (DarkKnight[DMD])
crvtec + boost
Old Sep 9, 2002 | 10:16 AM
Bullet50's Avatar
Default Re: CR-Vtec or Boosted B20 (flexmyREX)
I'd love to do both but theres a budget. For right now its got to be one or the other.
B50
Old Sep 11, 2002 | 03:53 PM
Bontke's Avatar
IF I was you I would start with the stock b20 and turbo. Don't go overkill on the boost but with the right tuning 10psi is achieveable. Selecting the correct impeller trim ratios and A/R ratio will make the turbo spool where you want it. My dream is a B18 or B20 that will have full boost right after 3,000 RPM. No VTEC needed there. Just a flat torque curve all the way to redline.
Old Sep 12, 2002 | 01:46 AM
Bullet50's Avatar
Default Re: CR-Vtec or Boosted B20 (Bontke)
I agree................ I'm gonna boost the B20 for now. Maybe a VTEC head down the road. Thanks,
B50
Old Sep 12, 2002 | 05:12 AM
DevinW's Avatar
Boost for sure!
I'm just gonna stick with N/A B20 NON-vtec ....
Old Sep 16, 2002 | 01:09 AM
SSBP DC2's Avatar
Default Re: CR-Vtec or Boosted B20 (DevinW)
a lot of you guys are boosting the b20...which i want to do too...but are you guys using stock internals? or forged low cr internals? i figure if i go forged internals it'll be $1g more since 800 for the rods/pistons and 200 for to balance and blue print the block...but it will be worth it in the long run...and then again, my budget is limited so i rather not have to do that unless i really need to.......anyhow, stock internals? or forged low cr internals? (for those who are running the b20 turbo)
Old Sep 16, 2002 | 08:47 AM
Bullet50's Avatar
Default Re: CR-Vtec or Boosted B20 (NA builder)
I know of a guy locally who is running boost on stock internals. The most he runs is 5 PSI so he doesn't blow the engine. If you're gonna run boost and want the performance do the internals, etc. and pump up the volume..........
B50
Old Sep 16, 2002 | 10:56 PM
SSBP DC2's Avatar
bullet50...what are your mods on the b20? what do you have for internals? what cams do you have? and what ecu are you running? thanks
Old Sep 17, 2002 | 02:30 AM
Bullet50's Avatar
Mods are in progress...................... I will be using 94+ LS Integra ECU, Eagle Rods, Arias or Crower Pistons (9.5:1), LS cams, AEM adjustable Cam timing gears, and the Crank will remain stock.
B50
[Modified by Bullet50, 7:30 AM 9/17/2002]
b184life
Mar 10, 2009 08:00 PM
90civicturboed
Oct 8, 2005 07:09 PM
ridestrt
Oct 13, 2003 06:10 PM
mi2lo4u
Nov 15, 2002 07:42 AM
