shock forks
Old Jan 26, 2010 | 11:26 PM
worx's Avatar
Default shock forks
is there a diffrence between ek and eg forks?
Old Jan 27, 2010 | 10:19 AM
worx's Avatar
Default Re: shock forks
anyone
Old Jan 27, 2010 | 04:24 PM
jhammond_82's Avatar
Reject Papi
https://honda-tech.com/forums/suspension-brakes-54/eg-vs-ek-suspesion-can-you-swap-them-2228670/
Old Jan 27, 2010 | 05:07 PM
worx's Avatar
it would help if it talked about the front no the rear lcas
Old Jan 27, 2010 | 07:12 PM
ek4_b16a's Avatar
the 99-00 civic si's fork are a bit wider.
d-series civics not sure. on majestic honda's site they show different product numbers. you can try calling two different stealerships for part numbers for each?!
Old Jan 27, 2010 | 08:17 PM
hushypushy's Avatar
I'm not sure if there's any difference in the forks, but you can swap EG and EK front shocks without changing the forks.
EF and EG/DC/EK front shocks are interchangeable if you swap the forks. This works out nicely on later models because EF front shocks are shorter.
Old Jan 27, 2010 | 10:29 PM
worx's Avatar
my friend was thelliing me that the ek forks will make you eg stand a bit higher
Old Jan 28, 2010 | 05:06 PM
ca-rs's Avatar
I have both sitting in front of me and they appear to be exactly the same in all dimensions.
Old Jan 29, 2010 | 08:56 AM
worx's Avatar
thank you ca-rs
Old Feb 24, 2010 | 10:03 AM
WickedSol's Avatar
So, your saying that the eg/ek forks are the same? Which ek forks do you have? I have heard that the EK SI forks are wider between the fork legs. Can anyone confirm this? I know that the EG and DC forks are the same.
Old Feb 24, 2010 | 01:25 PM
hushypushy's Avatar
EG, DC, EK forks are all the same. In fact a lot of companies (e.g. Skunk2) don't even make 96-00 specific suspension. They give you EG/DC suspension and washers for the rear LCA's.
Old Feb 24, 2010 | 02:08 PM
98civdx's Avatar
Master Detailer
99-00 civic si has differnt forks, that is way you need to change them when you use si lower conrtol arms. i have never noticed a difference with any others, give me a little while and i will go check, i have si forks and dx forks and i will compare.
Old Feb 24, 2010 | 03:15 PM
98civdx's Avatar
Master Detailer
just compared them, the si is wider and looks to be appox 1/4 longer. i pulled both and set them side by side,
99-00 si IS different. my dx fork cant go over a si lca, they do also look to be a different shape, my guess would be to clear sway bar.
Old Feb 24, 2010 | 04:36 PM
TheJGB3's Avatar
This is because the lower control arms on the Si are different then all of the D16 models. In other words you would need Si lower arms to use them. Also you would need the Si front swaybar.
Old Feb 24, 2010 | 04:41 PM
98civdx's Avatar
Master Detailer
^^ i know. you basicly said what i said but added the part of sway bar.
BlitzSix
Mar 18, 2009 12:01 PM
FSRslug
Mar 2, 2009 07:03 AM
98slvrcx
Aug 20, 2003 06:22 PM
Breeze
Aug 11, 2003 11:25 PM
acura_typer
10
Oct 11, 2002 05:19 AM
