True Defenition of TDC
Old Sep 5, 2002 | 08:16 AM
Resurgent's Avatar
Default True Defenition of TDC
Did valve adjustment over the weekend - first time, went well . I have the helms and about 6 different "How To's" from different sites that I used to guide me through. I have one question , when I was turning the crank 180deg for the 90deg duration of the cam sprockets for bank 1 I noticed that when the 2 small markers match up perfect for both intake/ext that the two arrows are not pointing straight up, but maybe to the slight left. When I turned it back so they face up the smaller markers abviously were not lined up anymore. I found this strange only because there was a considerable difference in the valve clearence between the two. This is a B18c1 01' GSR used - what "should" I be going by , the arrows or the small indentions on the cam sprockets ? I went ahead with the small marks and seems fine but could be a little more quite when cold - could my timing be off ? or possibly already advanced/retard by the previous owner ? THANKS !!
[Modified by PlantedGSR, 9:17 AM 9/5/2002]
Old Sep 5, 2002 | 11:12 AM
Resurgent's Avatar
Default Re: True Defenition of TDC (PlantedGSR)
Anyone ... ?
like in the first pic - the arrows appear to be to the left , and I asume the marks are lined up - this is bank 1
http://bseries.net/images/garage/val...amGearsTDC.jpg
bank 3 seems to be the same way -
http://bseries.net/images/garage/val...arsExhaust.jpg
But check out bank 4 - you can plainly see that the small indention is NOT lined up and the marks on the sprocket spoke is straight up
http://bseries.net/images/garage/val...mGearsDown.jpg
and then last bank 2 seems a little to the left
http://bseries.net/images/garage/val...earsIntake.jpg
heres another pic of a B18c at TDC
http://hazone.com/howto/pva006.jpg again a little to the left
And heres the helms instruction -
http://jdmfan.com/technical/performa...ent/helms1.jpg & http://jdmfan.com/technical/performa...ent/helms2.jpg
FYI - I did not locate the marks on the crank pulley due to visability , only on cam sprocks - Hope pics help exsplain my question !
Old Sep 5, 2002 | 11:43 AM
sgT's Avatar
sgT
TDC means Top Dead Center, meaning the piston is at the very top of its stroke.
Your cam gears "up" markings look off because the motor is tilted forward.
Old Sep 5, 2002 | 12:49 PM
raene's Avatar
Default Re: True Defenition of TDC (sgT)
So we should go by the markings on the pulleys, then?
Old Sep 5, 2002 | 12:58 PM
sgT's Avatar
sgT
Default Re: True Defenition of TDC (raene)
yes, line up white mark on crank pulley and the side marks on the cam pulleys
boostedteg4dr
Engine Management and Tuning
Apr 16, 2013 02:16 PM
Flatland2D
17
Apr 28, 2007 11:32 AM
Civicman86
Jun 21, 2006 08:07 PM
flangemastermike
May 29, 2006 05:03 AM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
