90 accord won't start when cold
Old Jan 26, 2010 | 10:15 AM
yankeesullivan1's Avatar
New User
Default 90 accord won't start when cold
everytime it gets below freezing my accord won't start, I replaced the main relay unit but that wasn't it. any help would be great
Old Jan 26, 2010 | 07:02 PM
fleetw00d's Avatar
Default Re: 90 accord won't start when cold
Need a bit more info. The engine won't crank? Starter just clicks? Cranks very slowly? Cranks fine but won't fire? Cranks, a cylinder fires occasionally, but won't run?
Old Jan 27, 2010 | 06:39 AM
Timmer_7's Avatar
New User
It could be your battery going bad, or you do not have enough cold cranking amps to start the car in cold weather.
Old Jan 27, 2010 | 07:48 AM
New User
new battery installed 2 mos. ago, when i turn the key there is a click and the fuel pupmp runs for 2 sec then shuts off, replaced the main relay, took it too a guy and he said it may be another (starter relay)?) when it warms up outside- above freezing ot starts right up. when i turn the key nothing happens, all other syastems work.
Old Jan 27, 2010 | 11:41 AM
Remiss's Avatar
could just be your starter going bad ... mine does the same thing but one could thump on the starter and she'll start
Old Jan 30, 2010 | 06:22 AM
uccjxe's Avatar
If there's not cold crank, it does sound like the starter. You can buy replacement contacts for the starter for a few dollars (dealer, driveline, and maybe partstrain) and that will probably get you more life out of the starter. You will have to pull the starter and open it up a bit to replace them - not hard to do.
Old Jan 31, 2010 | 07:21 AM
ncoutlaw's Avatar
ok try this . this is what i ended up with after 300 in parts . change the dizzy . the ECM is bad . its inside the dizzy .{ ignition control module }it was easier for me to change the whole dizzy . or you can just replace that part . where im at it was an 10buck price difference .
Old Feb 26, 2011 | 03:21 PM
timpletcher's Avatar
Having a similar problem with '02 accord. Won't start when it drops below freezing, buts starts right up every time it thaws, I'll try the "dizzy" and the ECM with it, and let you know what happens.
Matt S.
Jan 31, 2016 11:24 AM
spaman
Sep 14, 2012 11:20 AM
JDM_d15b_eg8
Oct 11, 2007 03:55 PM
Sexy_Chantal
Oct 28, 2004 04:18 PM
Accord15
Feb 20, 2003 02:16 PM
