I need suspension help for my sol
Old Jan 25, 2010 | 09:19 PM
mish__'s Avatar
Default I need suspension help for my sol
So trying to take off my Shocks to replace them with my other shocks and coilovers, but the nut won't come off. I tried spraying wd-40 on it, but it still won't budge. The nut is located on the fork. I've been using it regular socket and it just wont move no matter how hard I try. Is there a way for me to loosen the bolt or take off my shock without taking the fork off?
Old Jan 25, 2010 | 09:25 PM
97ej6dx's Avatar
Default Re: I need suspension help for my sol
If you have air tools they help if not is there any thing you can use to freeze the bolt? when metal frezes it conracts and often times you can losen bolts by freezing them I know canned air turned up side down works amazing at freezing things.
Old Jan 25, 2010 | 09:27 PM
XxDrUnKnMuNkxX's Avatar
I dont think its possible to take the shocks out without removing the fork. I know the nut is welded on so be sure you are loosening the bolt side. other than WD40 or PB blaster I would use a breaker bar or anything else you could find to extend your wrench like a jack handle. I know a lot of people who know they are going to take out their shocks will spray it with WD40 a day or two in advance, you might just need to give it a little time to soak in.
Old Jan 25, 2010 | 09:30 PM
mish__'s Avatar
Yeah, have an air compressor. I'll try it. Just hate hearing horror stories of bolts snapping.
Old Jan 25, 2010 | 09:36 PM
thumper64's Avatar
work the bolt in and out and don't force it too much one direction. Like try to turn it 1/4 turn out, then back in 1/8, then out 1/4... An air impact does work amazing though...
Old Jan 25, 2010 | 09:46 PM
97ej6dx's Avatar
just like sex.. nice and easy
Old Jan 25, 2010 | 09:47 PM
JdmOdz's Avatar
Heat it up witha torch then try loosening it. Should come right out. Bumpp
Old Jan 25, 2010 | 09:49 PM
mish__'s Avatar
Yeah have the compressor running right now. been trying to change my shocks all last night and tonight. The back forks are a bit small, so my brother told me to sand them down.
Old Jan 25, 2010 | 09:51 PM
mish__'s Avatar
Thought of the torch. Couldn't find it.
Old Jan 26, 2010 | 09:30 PM
thierry's Avatar
PB Blaster works wonders. I used it for my LCA bolts that were seized in the bushings. Spary on a day in advance. Then while you work on it. Try tightening slightly then loosening slightly. In like a back and forth motion, work it.
P@@RB@Y
Jun 25, 2006 12:20 AM
sooo_slow
Nov 4, 2005 06:53 AM
krnfly2damoon
Suspension & Brakes
Jun 18, 2005 04:51 PM
Xerxes3333
Aug 2, 2004 06:24 PM
99ls
Dec 22, 2001 06:11 PM
