b20vtec build question
Old Jan 25, 2010 | 05:17 PM
betojr82's Avatar
Icon4 b20vtec build question
I am planning on building a all motor b20vtec, using a gsr head and high compression pistons. When it comes to the building of the block, would it be better to use aftermarket gsr parts ( crank and rods) or would it be better if i use aftermarket b20 parts???
Old Jan 25, 2010 | 10:31 PM
ghosthatch's Avatar
Default Re: b20vtec build question
you need the b20 parts. piston sizes are different
buy forged rods(with arp studs) and forged pistons. some people use a block guard. i do
get a oil breather kit bc you wont have a pcv system and you wanna stop all that blow by from getting back into your engine with all the gases
buy the golden eagle vtec conversion kit too
good luck, sounds like you need to do a bit more research
Old Jan 27, 2010 | 06:35 AM
betojr82's Avatar
dont get me wrong i know u need all the parts u mentioned. its just that i have heard that if u heard that if u build a b20 block using a gsr crank, rods and b20 pistons that its a beast.
Old Jan 27, 2010 | 06:55 AM
4g4dcruisin's Avatar
Well besides the obvious diameter differences, is the height different?
If the GSR/B20 crank are the same in terms of lobe height/width, and the connecting rods are the same from GSR/B20. then why wouldnt you be able to use them?
If the ONLY difference between the GSR/B20 block internals is the piston diameter, then **** use the B20 pistons and GSR the rest of it.
IF thats the only difference im saying.
Old Jan 27, 2010 | 11:11 AM
hatchbackattack's Avatar
B20 crank has a longer stroke than the GSR; 89mm vs. 87.2mm.
Old Jan 27, 2010 | 11:27 AM
.Manny.'s Avatar
Touching My Member
My B20VTEC has "1.8 internals."
B20 Block Stock Sleeves 84.5mm
RS MAchine ITR style pistons
GSR/ITR Eagle Rods
ITR Crank
you can't mix rods and crank. ITR/GSR stroke is shorter but with longer rods and vice versa for B20/LS.
I personally chose the ITR crank because I got a good deal on it and the rods and I had driven a few built this way and they revved smooth as hell.
Old Jan 27, 2010 | 05:22 PM
ghosthatch's Avatar
stick with the b20 crank, you wont be disappointed
but i havent tried the gsr crank/rods so idk really. but mine revs just fine and fast if thats all
Old Jan 27, 2010 | 05:40 PM
.Manny.'s Avatar
Touching My Member
both are great. just make sure you don't cheap out and build it right the first time
Old Jan 27, 2010 | 06:47 PM
ghosthatch's Avatar
many peoples problems. i myself cant decide whether to dial my engine in with a dial kit but then i have to buy it and new gauges if it doesnt come with 3 and thats a lot extra
Old Jan 27, 2010 | 06:48 PM
betojr82's Avatar
thanks for the imput guys.. i was just wondering since with tax money i plan on buying everything for the bottom end. i already have the oil pump, vtec conversion kit, water pump, timing belt, arp head studs, new tentioner..... i think that all i have....lol
im planning on using gsr parts for the bottom end too see how it goes. since i have already built a b20 using b20 parts, and it was a beast......
jdragon1974
20
Aug 7, 2014 12:29 PM
vtak2nr
Jun 22, 2011 06:49 AM
ghosthatch
Oct 4, 2010 12:08 AM
LaOstha
Jul 5, 2006 05:35 PM
Mentat Ghola
10
Apr 16, 2004 06:07 AM
