Pro's and Cons about buying a USED ITR rear sway bar...
Off of a 2000 ITR with 20000 miles on it? Should there be any concern?
Also, can anyone vouch for the user riksride (22 posts, white plains ny)?
https://honda-tech.com/zerothread?id=269975 (This is the "for sale" post)
TIA
Ohlias
TIA
Ohlias
There shouldn't be any concern about purchasing a used Type-R rear swaybar. The only thing that might show some wear is the endlink bushings.
I can't respond as to how it would effect your warranty, but the mod is definitely worth it.
If you can't verify otherwise, just wait until your warranty expires... the BSQ/Beaks mod requires some drilling into your rear crossmember.
"Sorry, do not have pix. Bar is in excellent shape w/bushings but no
brackets. It came off a 2000 ITR. I really didn't want to ship but if your
really serious, let me know."
The seller sent me this email. Without these "brackets" will I still have all that I need?
Ohlias
Ohlias
I don't forsee any problems in buying a used ITR sway bar other than it's eaten a GSR subframe in the past and it's hungry for more
eh?
eh?
a new one with all parts is only $103 USD, this is priced with everything right off bsq's inventory list, and u should do better because you guys are in the states.
I just ordered mine in canada new, sealed, at dealer for that price.
I think it might be the better option, seeing as u might have to replace the endlinks anyways.
-Rage
-Rage
I don't see any cons from purchasing a used sway bar.. theres not much that can go wrong.. unless you want an absolutely new bar.. the only con is that it might have some scratches/wear..
