So we all know bosch plugs are terrible right...?
Old Jan 24, 2010 | 09:02 PM
ONYX S-13's Avatar
Default So we all know bosch plugs are terrible right...?
I wanted to post this when it first happened but I misplaced the scans on my computer and finally found them again.
After I failed, I sea foamed the car and changed the plugs with some NGK's.. I highly doubt that sea foam alone changed the results of the smog that much but if it did that product deserves some kind of award(s). I was shocked at how bad the boschs worked and they had less than 20 miles on them!
FYI: This was on an out of state car.
Old Jan 24, 2010 | 09:49 PM
Linked's Avatar
Default Re: So we all know bosch plugs are terrible right...?
seafoam can work wonders some times, it depends on how much carbon buildup you have. but maybe the boschs werent gapped right, with only 20 miles on them, they should have been pretty good
Old Jan 24, 2010 | 09:56 PM
ONYX S-13's Avatar
I don't think the sea foam did that much because the smoke from the tail pipe was barely anything.
Isn't the smoke the determining factor of how much carbon is in there?
Also, the bosch's are supposed to be pre-gapped for our cars.
Old Jan 24, 2010 | 10:21 PM
Linked's Avatar
nah smoke should pour out regardless of carbon,
but the proper way to apply seafoam is 1/3 gas tank, 1/3 pour into intake manifold, and 1/3 into the oil i believe (then change it of course)
Old Jan 25, 2010 | 11:13 AM
ONYX S-13's Avatar
Yeah that's what I did (I've sea foamed 4 other cars before but not for smog purposes).
Hmmmm. I know on my 01 Galant and the civic the smog is from barely had smoke. The civic that I have right now I sea foamed about a week ago and it completed dwarfed my other cars (excluding my 89 240sx).
My 240 had 250K miles when I did it on the original motor and the civic that I have now has 288K on it.
Old Jan 25, 2010 | 03:05 PM
Arthas's Avatar
Did you notice a huge difference in the way the engine ran after sea foam?? Im thinking of doing that before boost, but im unsure of how great it works.
Old Jan 25, 2010 | 03:49 PM
ONYX S-13's Avatar
Nope. I can't say that I did.. I know it didn't run worse that's for sure. If there were advantages to using the sea foam I couldn't feel/notice them.
shortlid
Mar 11, 2011 10:42 AM
EG2Driver
Sep 19, 2005 06:20 PM
SHELLS01LUDE
Jun 24, 2004 03:09 PM
hondalude9394
Feb 15, 2003 02:55 PM
Leo95SE
Jul 23, 2002 07:09 PM
