How do you take off ignition switch?
My ignition was busted and I wanted to replace it, but I don't know how to take off the bolts on it. Here is a picture of what I'm talking about. It's circled in red.
loosen the two bolts under the steering column to drop the column down, then you have room to get a cut off wheel in there, dont cut them off but grind a slot in them so you can use a screw driver to loosen them. hope that made sense
