EM1 --> D16Y8
I'm dropping a fully built Y8 into an EM1 chassis.
My question is, what will need to be modified, as far as the harness, for it to work?
The harness that's on my Y8 has a messed up secondary O2 circuit. Worst case scenario, I can put it in with the correct harness.
if you put it in your EM1 i'm assuming SI you should be able to use the stock si harness.. i think the smog sensor has to be moved around but that's all i can think of
Good luck with the swap
The only thing that has thrown me off is that the reverse sensor on the tranny is all soldered in from when the person who had the car prior swapped it... not sure what's the deal with it.
Dstaks716
Sep 6, 2010 06:55 PM
My JDM EJ8
17
Dec 19, 2008 06:08 PM
