b16 block vs. b18 block
damn near everything is interchangeable, the deck height is different (LS is 7 mm taller) so the rods are not interchangeable, unless you are using soem custom stroker crank or something, other than that, everything is pretty much interchangeable, some of it requires slight modification.
Yes, the oil pump is interchangeable, no moification neccacary.
BoostedGSRBubble
Feb 15, 2003 09:38 PM
