5-lugin question
Old Jan 24, 2010 | 06:32 AM
Paulie Pesos's Avatar
Default 5-lugin question
Heres a pick of my R with my project civic:
The Question:
looking to take my civic to the track instead of using my R. Instead of going on Passwordjdm and buying a 5 lug conversion for a ton of money, why cant i just replace the hubs on my civic with a 5 lug hub? ive never herd of anyone doing this and from what i have researched i can:
-Put integra front assembly on civic
-Get hubs and bearings all the way round
-01+ Prelude or Type R calipers and rotors
and thats it....why have i never herd anyone taking this cheaper route when doing a 5 lug conversion? I can have a 5 lug conversion for under $300-$400
Old Jan 24, 2010 | 10:13 AM
jaykerp92eg6's Avatar
Default Re: 5-lugin question
I haven't heard of anyone doing this but also never heard why you couldn't either I'm going to look into this cause this could be an easy way to do 5 lug
Old Jan 24, 2010 | 11:06 AM
mrharmonic's Avatar
dont go to password way to expensive and over rated go to hmotors ther five lug conversion is only 800 bucks
Old Jan 24, 2010 | 11:47 AM
Bucc-i's Avatar
You would need the ITR knuckles as well. I was thinking about doing this a couple of years back. And just decided to buy the whole conversion. Was kind of scared I would press the bearings wrong or something. Besides, new bearings (and I would only buy them new) are way too expensive anyway.
Old Jan 24, 2010 | 02:19 PM
keepinitrehaal's Avatar
Never thought of it. Would like to know if this would work too. If it does, this would be my next project.
Old Jan 24, 2010 | 03:31 PM
USDMCIVICHATCH's Avatar
doesn't work because type r rear spindles are longer then ls/gsr and acura only sells the rear spindle with the trailing arm... way too expensive because of that... it is much cheaper and easier to buy used complete type r suspension...
or you can use a mazda axle nut on the rear and risk a wheel rolling past you on the highway... not very safe...
Old Jan 24, 2010 | 04:51 PM
94rs-turbo's Avatar
just buy a 5 lug set up, my buddy has one fs if you would be interested
Old Jan 24, 2010 | 06:10 PM
hOnda_hiEn's Avatar
its do-able.. check it..
https://honda-tech.com/forums/showth...ersion+spindle
kevinm1981
Suspension & Brakes
Feb 24, 2010 05:03 PM
Turbo_Teg
Sep 11, 2002 06:51 PM
