wut are the best settings for a Vtec controler
Old Sep 4, 2002 | 10:30 PM
FLIPboi's Avatar
Default wut are the best settings for a Vtec controler
i just got my vtec controler in and i dont knoe wut settings for my civic ex to make me have good prefoments, my mods are cai , fuel regulator , cat back exhost, and underdrive pully, so wut would be the bast setting for my vtec controler??
Old Sep 4, 2002 | 10:33 PM
turbo craig's Avatar
Default Re: wut are the best settings for a Vtec controler (FLIPboi)
go to a dyno make a run on only the normal lobe then make a run only on the vtec lobe and where they cross theres ure optimum vtec point
Old Sep 4, 2002 | 10:34 PM
FLIPboi's Avatar
Default Re: wut are the best settings for a Vtec controler (turbo craig)
what about my fuel do i have to do any thing to that ???
Old Sep 4, 2002 | 10:37 PM
umm u have just a vtec controller? all that does is adjust where vtec engages
Old Sep 4, 2002 | 10:41 PM
FLIPboi's Avatar
but would i have to addjust my regulator to compreent with my vtec for more HP???
Old Sep 4, 2002 | 10:57 PM
MikeSarr_GSR's Avatar
every engine is different. if you dont tune that thing with a wideband O2 and a dyno you could be running super lean and cause damage... in GT3 things dont break... here you have to know whats up
Old Sep 4, 2002 | 11:02 PM
Default Re: wut are the best settings for a Vtec controler (MikeSarr_GSR)
i like that but with thoes mods dont wory stock fuel pressure will b fine
Old Sep 4, 2002 | 11:05 PM
I am just trying to get our friend to realize the need for a 5 gas O2 sensor for proper tuning... you will get so much farther faster, safer on a dyno with the right person interpreting the data. 15-13afr is stoich or target... sometimes adding fuel helps also, I have no first hand exp with this aspect of tuning yet however, I have seen others do so in the shop. hope it turns out good.
DARKTEG_
Aug 31, 2006 10:37 AM
mdj_ge
Jun 29, 2005 09:28 PM
gsrallday
Nov 7, 2003 12:14 PM
killa_lude
Aug 1, 2003 07:01 PM
