ls-v with gsr or ls crank/rod????
Old Jan 22, 2010 | 10:18 PM
krazy newbie's Avatar
Default ls-v with gsr or ls crank/rod????
so im doing my ls-v build...should i stay with the stock ls crank/rod? or switch them all out to gsr??? give me the pros and cons plz
Old Jan 23, 2010 | 03:57 AM
zedron's Avatar
Default Re: ls-v with gsr or ls crank/rod????
Purpose of building a "LS/v" is for the LS parts. These parts are the crank and rods. Depending on what pistons you decide to use, whether they are OEM type or aftermarket. If you switch to a GSR crank/rod then you would really just have a GSR bottom end + or - the block girdle in an LS block. Then you also wouldnt have the oil squirters that are located under the pistons. You would basically be doing an LS/V for no reason.
Old Jan 23, 2010 | 05:27 AM
fasthatch95's Avatar
are u planning for some boost or n/a?
Old Jan 28, 2010 | 01:18 PM
slide inside's Avatar
thanks answers my q's
Old Jan 28, 2010 | 02:44 PM
TheWhopper's Avatar
I'm guessing you have a GSR block.
I have an LS crank...still debating on whether or not I'm going to use it when I rebuild my GSR block.
Most likely.....not.
Either the LS rods...or GSR pistons will need to be shaved for them to fit each other. I was thinking about using eagle rods since I don't know how reliable those LS rods are in a motor that's meant to rev higher.
All in all I calculate I would have to spend $300 for the eagle rods (when I could use the stock GSR rods)...plus pay the machine shop $100 for the shaving, plus the LS crank (another $100)...plus worry if this motor will need to be re-opened in 3 years since I don't know how reliable the setup is....all for a small/decent amount of torque.
Definitely not the biggest bang for your buck at $500.
Since I don't have that large of a budget..I'm most likely (unless a pile of money lands on my lap) going to stick with my GSR crank and rods.
To each their own
Old Jan 28, 2010 | 05:34 PM
zedron's Avatar
To each their own
GSR and LS rods are the same in terms of material. The only difference is the size.
Old Jan 28, 2010 | 05:50 PM
TheWhopper's Avatar
The similarity in materials when comparing OEM LS rods and OEM GSR rods is moot.
My bad, didn't realize he has an LS block. Yeah...I would never recommend putting in GSR rods and crank in the LS. Defeats the purpose of trying to build the LS/VTEC.
Old Jan 28, 2010 | 08:02 PM
DC2fab's Avatar
huh? this thread is confusing me a bit. ls vtecs are built for the ls parts. you cant put a gsr crank in anything but a b18c block. if your doing a ls/v build you have to get an ls crank along with some other stuff like oil pump, main girdle, etc. but the gsr water pump, oil pan, and some other stuff will work on a ls block. im doin a ls/vtec build right now. i know all about the switch lol
Old Jan 29, 2010 | 10:08 AM
ls_vtec_da's Avatar
Ls crank has about 1834cc correct if i am wrong and gsr has about 1782cc about not sure but ls has a bigger stroke that is the point of a LS-VTEC and ls rods are the strongest oem rods
Old Jan 29, 2010 | 10:28 AM
zedron's Avatar
You are wrong ona few things.
1) LSv are mainly built for the LS rods/Crank to get the bigger stroke. Ls blocks are used because they are cheaper and easier to get than a GSR and when you find them they will ususally be a shortblock. I have seen people selling LS shortblocks for 100-125 and you get almost everything you need plus some.
2) You can use a GSR crank/rod combination in any B18 motor..
2) LS do not have block girdles.
3) You only have to use the GSR oil pan, pickup/ windage tray IF you use the girdle.
4) You can use an LS oil pump if it is from 96+. All B18 oil pumps from 96+ are the same whether it is LS, GSR, or Type R.
You do need a Vtec water pump and a GSR timing belt.
LS motors dont have a girdle.
HondaAddict91
Engine Machining & Assembly
Oct 9, 2016 06:37 PM
Mostecstreethb
Feb 19, 2007 02:19 AM
pimpnpink
Feb 8, 2007 01:05 PM
EH2LS
Apr 29, 2004 08:24 AM
decypha
Feb 14, 2003 09:13 PM
