it keeps revving
Old Sep 4, 2002 | 09:38 PM
00ekcoupe's Avatar
Default it keeps revving
my friends hb revs by itself, can anyone please help. he said it has to do something with the distributor or something. he has a 92 eg dx. can this problem be fixed easily by ourselves or does it need to go to the shop. thanks for all the help.
Old Sep 4, 2002 | 10:34 PM
tinkerbell's Avatar
Default Re: it keeps revving (takiraj)
it might have something to do with a vacuum leak,
what do you mean - revs by itself?
t..
Old Sep 4, 2002 | 11:32 PM
seano's Avatar
Default Re: it keeps revving (tinkerbell)
Happened to me alot in my old truck, it was just some slow moving throttle cables.
Old Sep 5, 2002 | 12:10 AM
Kamin's Avatar
it sounds like a vacume leak.
if it was a dist. problem the engine wouldnt get enough air (because thats how an engine works, you give it air, you then give more fuel, then spark. if its getting too much spark and the throttle plate is closed it will just detonate and not do anything but sound horrible.)
Old Sep 5, 2002 | 02:29 AM
ninesecrx's Avatar
Default Re: it keeps revving (KAMiN)
How high does it rev and do you hear any major vacum leaks? It can be a sensor related problem as well. You need to give us a little more description.
Old Sep 5, 2002 | 09:22 AM
cinq's Avatar
the car is haunted.
Old Sep 5, 2002 | 11:16 AM
RockDawg_GSR's Avatar
yes, it does sound like a vacuum leak.Do you hear anything differant as it revs higher? Maybe something is wrong with the pedals
Old Sep 5, 2002 | 11:39 AM
00ekcoupe's Avatar
Default Re: it keeps revving (ninesecrx)
it revs up and down, probably til about 3krpm then down then up...
Old Sep 5, 2002 | 01:40 PM
Kamin's Avatar
its a vacuum leak
take carb cleaner
spray it around the intake manifold and throttle body gasket.
when the idle starts to steady out, you found the leak.
also take off the idle air control valve and clean it
Old Sep 5, 2002 | 01:41 PM
smokin rubber's Avatar
if its only when the car is cold it is the fast idle valve
einzelherz
23
May 8, 2013 09:56 AM
replicaITR417
May 7, 2010 08:32 AM
supermario680
19
Feb 17, 2009 05:26 PM
tcr03
13
Feb 23, 2005 10:13 AM
ricky_gunns
Apr 9, 2003 04:18 AM
