d15 build or b16/h22 swap
Old Jan 22, 2010 | 10:54 AM
mashitup's Avatar
Default d15 build or b16/h22 swap
i own a 90 civic si with a stock d15 and i was wondering if anyone could give me advice on wether i should do a mini me swap and rebuild the bottom end or would it be more worth my time to just save up for a complete b16 or h22 swap im tryin to save as much as possible and lookin for around 250 whp or more, also forced induction is in my future so can anyone help me out?
Old Jan 23, 2010 | 12:25 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: d15 build or b16/h22 swap
if its a 90 civic SI, you should have mpfi and a d16a6, not a d15.
h22 will be a nightmare. just go with a b16 or a mini-me for your first project. even though there is a mount kit for the h22, you spend as much on the mount kit as you would for a full d16z6 swap.
Old Jan 23, 2010 | 06:37 PM
mashitup's Avatar
yeah i take that back it is a d16a6 with mpfi so what kinda power gains would i get with the mini-me and a built bottom end new pistons and rods etc. maby bore it out too,, also does anyone know where to get that center bumper piece that goes between the hood and actuall bumper ive been looking all over
Old Jan 23, 2010 | 09:13 PM
91hatchproject's Avatar
From: lancaster, ohio (pronounced "lankers uh-hi-ya")
mini me is typically when you put a v-tec head on a non v-tec bottom end
The motor you have already has a v-tec head
Why would you do a mini me?
If i were to spend all of the money on building up a block,
i would go b series
Just my $.02
Old Jan 23, 2010 | 09:28 PM
BRICKS's Avatar
if you want to keep your d series expect to get very good at tuning or pay for good tuning. if you want power without as much fine tuning. go b.
Old Jan 23, 2010 | 10:06 PM
sanimalp's Avatar
$cat /dev/urandom
i would go b series
I think you answered your own question. I recommend a mini-me or a d swap because they can be had for dirt cheap. I have a "hot spare" working d engine in my garage, and 3 different good transmissions to go with it, and i think i have spent about $250 so far on everything.
If you are just starting out, and want to get your hands dirty with no money, then d-series is the way to go. learn on the d and then move to the b. you can afford to blow up a few d blocks learning, but unless you have deep pockets, that wont happen with the B or the H.
Of course, i have no idea of the OP's situation.. so its my $.02 as well.
Old Jan 24, 2010 | 07:02 AM
89s1's Avatar
i would go b series
Just my $.02
D16A6 engines have vtec now??
Maybe you should read more, and post less.... just a thought.
If you plan to boost then stick with he d16a6. They take boost really well. What you would spend on a b16 swap spend on a bulletproof bottom end for the d16.
Old Jan 24, 2010 | 12:08 PM
DazeMS's Avatar
rebuild the d16a6, rods pistons, rings, bearings.. hone the block , have the block hot tanked, decked, balance the rotating assembly, , work on the cylinder head.. do a mild port, 3 angle , update the valvetrain, better cam for turbo.. 440cc mitsu injectors, fuel pump to 255lph walboro .. chip ur ecu.. OVER 200whp for around 2500-3k .. which would cost about a bswap... done
Not everything done in that particular order or fashion, just a list as they came to mind lol
Old Jan 24, 2010 | 05:52 PM
KINGVEM^^ED6's Avatar
Booooosted D
Old Jan 26, 2010 | 08:21 AM
mashitup's Avatar
thanks for the help ill keep this list in mind and build up the d rather than do a whole swap and keep you guys posted on the build
clay0521
Jan 6, 2013 06:28 PM
jlotz19
Jun 24, 2009 12:10 AM
rleonekc
Aug 20, 2006 12:05 PM
jdm91civichbH22
Sep 2, 2004 08:51 PM
93preludes
Oct 19, 2003 12:43 PM
