B18b backdating to obd1
Old Jan 21, 2010 | 08:31 PM
LS-turboner's Avatar
Default B18b backdating to obd1
i have a 97 obd2 b18b and it is going into an EF hatch. im running a p75 on hondata s100. what do i have to do to backdate the sensors and stuff to make it obd1? i know i need a obd1 dizzy, but what else is needed? any help is appreciated
Old Jan 22, 2010 | 01:09 AM
D16SiHatch's Avatar
Default Re: B18b backdating to obd1
You need nothing, not even a new dizzy. Just rewire the one you have with obd1 plugs. They are the same internally. You can leave the extra evap stuff and ckf sensor unplugged because your ecu won't look for it.
Old Jan 23, 2010 | 12:33 PM
sanimalp's Avatar
$cat /dev/urandom
I can confirm you do not need a new distributor. the obd1 and 2 distributors use the same signal pattern that can be understood by either generation of ecu. otherwise rewiring of the plugs is all you need, as d16SiHatch already said.
Old Jan 24, 2010 | 06:55 AM
punkdown's Avatar
You will need to rewire the alternator plug or just use an OBD1 alt. I *think* the plug is the same between OBD0 and OBD1 (large round plug) and OBD2 is a smaller square one.
woodenchef
Jan 3, 2013 05:58 PM
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
clean_ass_rex
Jan 30, 2007 12:09 PM
jdmbeegee
Sep 6, 2006 08:58 PM
Civic
Jun 7, 2003 08:55 AM
