disk brake upgrade on EG
so to my understanding i can use the rear hub off a DA n bolt it on to my EG right? what about the front brakes? can i just take the whole spindle from the DA and bolt it on? my brakes suck right now
Idk about DA but I bolted the whole front spindle frome a dc onto my 93 eg si just had to change the master cylinder to a larger one and good to go. If your not in an si you have to put in a 40/40 prop valve if your running rear disc too
No used the mc from a 90-91 civic ex 4 door it's 15/16 and bolts right up to your stock lines and is the same size works great and it's cheaper but i have an si so it already had rear disc and prop valve
boush95 is right but i would recommend using a dc i know it odd but go on craigslist and type in rear disk breaks i found a shop that does it by me. a full set up for about 300 including the prop valve, trust try craigslist lol
not many shops here that do it (hawaii). n im using DA parts because i have one in front my house that i was parting out and i only got it for $100. anywho so EF brake master will fit and is bigger than the EG one? or should i go with a DC master cylinder?
It has to be from the 90-91 4dr ex I got mine from the local autozone brand new for like 30 bucks as far as the da prop valve i'm sure you can prob use it you just might have to modify the lines some
EG8steve
Jul 21, 2003 02:18 PM
