Car won't start
Old Jan 21, 2010 | 06:10 PM
St3v3's Avatar
Default Car won't start
I Replaced the heater hose and had to completely remove the distributor (not the cap) to gain access to the hose. After I replaced the hose, put back on the distributor and plug wires in correct firing order my car will not start. Car was working fine before I messed with the distributor. Any suggestions?
Old Jan 21, 2010 | 06:18 PM
tamadrummer1120's Avatar
Default Re: Car won't start
is it cranking?
if it is, you may have moved the rotor button inside. also make sure you plugged all the wires back into the correct position.
Old Jan 21, 2010 | 08:14 PM
PilotOnDubs's Avatar
you may have misaligned the rotor that connects to the camshaft...
remove the distributor assembly and see if you can rotate the rotor 180 degress and see if it bolts back up
Old Jan 21, 2010 | 10:35 PM
Slingshot88's Avatar
New User
Check the tire air pressure.
Alexander Smets
Jun 21, 2019 11:49 PM
Poedogg
Oct 3, 2017 07:38 PM
91wagonman
Sep 8, 2014 08:56 AM
street_ride14
Jun 3, 2007 06:46 PM
elnoyl
May 23, 2003 04:06 PM
