94 EX: replacing AT, what seals/gaskets needed?
Old Jan 21, 2010 | 10:21 AM
TravsD's Avatar
Default 94 EX: replacing AT, what seals/gaskets needed?
The AT in my 1994 Accord EX just grinds when I select reverse. Ruled out electrical probs, so I'm getting a used one. I have some Honda ATF and an OEM rear main seal. What else should I replace? I just read somewhere axle seals (where can I find them in the FSM? what page and number in the exploded diagrams?). I don't want to (and can't) overhaul the replacement tranny or anything, just want be diligent and avoid leaks. Trying to get this thing buttoned up for a good daily.
Thanks for reading,
TravsD
Old Jan 21, 2010 | 10:39 AM
1grex's Avatar
Default Re: 94 EX: replacing AT, what seals/gaskets needed?
The axle seals surround the (driven end of the) axles you can't miss them; they are pressed into the trans with a light interference fit
Old Jan 21, 2010 | 10:55 AM
TravsD's Avatar
On the car maybe, but the diagrams are a little...obtuse. They don't show how things relate to surrounding components well. I'm still deciphering the diagrams. I'm not familiar with this car (got it two weeks ago)...and only worked on MT before.
Old Jan 21, 2010 | 11:06 AM
1grex's Avatar
Seals on auto & manual will be similar if not the same, also torque converter o-ring is good to do while you're in there
Old Jan 22, 2010 | 04:47 PM
TravsD's Avatar
What about all the other gaskets and little o-rings inside? Let sleeping dogs lie? I don't know how long this thing has been sitting. Is there a chance they've dried up or something and may not be sealing well?
pityocamptes
48
Feb 19, 2013 02:34 PM
Emeraldbomber
13
Mar 26, 2012 01:51 PM
HellerDopeEK4
19
Jan 17, 2010 08:52 PM
