installing type-r cams
Old Sep 4, 2002 | 08:42 PM
black2001ITR's Avatar
Default installing type-r cams
I plan on installing toda spec b cams into my type-r, a friend of mine who is a mechanic is going to be helping me. do you guys know if you can use the original shims or do you have to get new ones??? or is there a way of adjusting them???
thanks for your help
Old Sep 4, 2002 | 09:55 PM
bryant's Avatar
Default Re: installing type-r cams (black2001ITR)
http://www.c-speedracing.com/howto/caminstall/cam.html
Old Sep 4, 2002 | 10:01 PM
Default Re: installing type-r cams (CR-X)
thanks alot for your help, that should come in handy
Old Sep 4, 2002 | 10:55 PM
MikeSarr_GSR's Avatar
things to look out for:
proper spec on the bearing caps 19-20ft/lbs on the 12mms, 8ft/lbs on the 10mms
be sure, I trusted my "tech buddy" and he said the spec was 28. it will cause a KNOCK if they are too tight and eventually freeze. Mine did after 800 miles trying to troubleshoot that knock... damn you could totally see it knock on the same frequency of the cams turning... oh well, thats an experience. At least it didnt bend any valves, just galled up the head and cams which I cleaned up and re-used. The motor eventually died 9K later downstairs from the up and down action of the worn journals... helped wear out a crank bearing.
Since you have an ITR, you have good springs and LMAs already, I would reccomend some brand of Ti retainers like the Skunks.
I hope your car runs awesome Hope this helps.
Old Sep 4, 2002 | 11:07 PM
4drlsvtec's Avatar
I would recommend that you get some stiffer valve springs if your going to be reving 8k alot... Too be on the safe side... So you won't get any valve float..
Ti retainers will also help lighten up the valvetrain..
Doug
Old Sep 4, 2002 | 11:09 PM
sparkz's Avatar
Default Re: installing type-r cams (4drlsvtec)
Also use an I-Beam type Torque wrench or one that reads in in-lb!!! Those big clicker types arent accurate and ratings that low (most at least)
wasanissanFL
Sep 3, 2015 10:25 AM
Na-Spirit
Dec 10, 2011 03:38 PM
1QwIkEf
Jul 23, 2010 08:26 AM
lluks_844
Feb 15, 2008 09:41 AM
1320DRAGWORKX
Nov 10, 2006 11:27 AM
