Lockless Door Handles???
Old Jan 21, 2010 | 05:12 AM
vodkaTM's Avatar
Icon2 Lockless Door Handles???
Is there a website that sells lockless door handles for 1997 Accords?
I saw an integra on craiglist with this done. I don't want to completely
shave the door handles, just without the locks.
Let me know if anyone has some information on this,
or where it can be found.
Old Jan 21, 2010 | 05:33 AM
GhostAccord's Avatar
Default Re: Lockless Door Handles???
I've never seen any sold with that purpose. However, Have you looked at trying to use a set of rear door handles from a sedan? they are the same shape and do not have a door lock mechanism on them.
Old Jan 21, 2010 | 05:51 AM
vodkaTM's Avatar
Wow, you're a genious! Why didn't I think of that... I'm gonna go to the junkyard and snag some and try it out. :D
Old Jan 21, 2010 | 05:59 AM
Good luck!
Keep us posted. I'm interested to know how it turns out. Post up a DIY or at least some pics if you get them to work.
Old Jan 21, 2010 | 06:07 AM
jdmwannabee's Avatar
don't forget to use this in conjunction with some kind of keyless entry....
Old Jan 21, 2010 | 06:40 AM
JuS JAi Bee's Avatar
New User
rear door handles is what i did for my civic worked wonders..
Old Jan 21, 2010 | 02:48 PM
vodkaTM's Avatar
Already have keyless entry set up in my car thankfully. But I will post a DIY with pictures after I finish. Stoked!
Old Mar 8, 2010 | 06:23 PM
Any progress with this? I'm interested in how it turned out.
Old Mar 8, 2010 | 06:49 PM
GlassJAw's Avatar
I'm intrigued by this also, how would you get into the car if the battery were to go flat??
Old Mar 8, 2010 | 06:54 PM
I'm guessing that you would need a (+) battery post hidden somewhere for boosting or a hidden hood release mechanism or fail safe switch of some sort. I'm sure it's been done, there are a lot of shaved door handle cars out there.
Old Mar 8, 2010 | 08:25 PM
uberEFtuner's Avatar
I did it on my 92 Accord Lx. I just had to shave down the metal where the bolts hold the handles on. AND LOTS OF TESTING. I got it stuck once and needed to cut a hole in my door panel to re adjust.
If you get locked out you can crawl through the trunk too.
Old Mar 8, 2010 | 08:52 PM
GlassJAw's Avatar
I guess that would only work if you had a key to access the trunk??
My car only has access from the interior of the car and keyless fob
Old Mar 9, 2010 | 05:41 AM
Or what if you shave the trunk, like I have. I don't even have a keyless fob. Only way for me to get in the trunk is from the interior as well
Old Mar 31, 2014 | 03:39 AM
swes2006's Avatar
4 year rise from the Grave thread…!!! I'm looking to see if this can be done…this worked in my 94 & 96 integra's but i don't know if it will be plug and play with the accord……..
Old Mar 31, 2014 | 04:32 AM
jvr's Avatar
jvr
Since this has already been resurrected...
Would this be purely cosmetic or would it add a small layer of security? My old 95 accord was stolen and the thief picked the lock rather than jimmying the mechanism through the window (as evidenced by a physically damaged lock)... Which method of theft is more likely/easier?
Old Mar 31, 2014 | 04:46 AM
I did this mod on my 96 and it wasn't exactly plug and play but it wasn't very hard to modify them to work.
The door rod opening mechanism needs to be swapped over from the front handle to the rear. Also the mounting tabs on the doors need to be made larger and drilled as the rear handle bolt holes are a bit different from that of the front handle.
http://ghostaccord.blogspot.ca/2010/...ved-doors.html
Old Mar 31, 2014 | 08:53 AM
swes2006's Avatar
nice..
bigedgar
11
Feb 28, 2016 01:04 PM
mataliandy
Jul 12, 2010 06:24 PM
DTMkarnage
Jun 15, 2010 01:02 AM
confusatron
Mar 20, 2006 09:41 PM
