chipped p28 in 00' EX
Old Sep 4, 2002 | 07:53 PM
SlowD's Avatar
Default chipped p28 in 00' EX
anyone every use this in a 00' D16Y8? If I use this ECU will it make my car OBD1? The ecu they want to sell me is "chipped" with a 5300rpm VTEC, adapter harness, 9100 rpm redline, agressive ignition maps, and fuel maps?? What will this do to my car's drivabillity? Thanks.
Old Sep 4, 2002 | 08:56 PM
ExospeedAMcrx's Avatar
Default Re: chipped p28 in 00' EX (SlowD)
it is not a straight plug in.
you have to do some rewiring.
Wil
Old Sep 4, 2002 | 09:02 PM
salbaje's Avatar
better fuel curves and vtec crossover. it will also eliminate 2nd o2 and crank sensor
Old Sep 4, 2002 | 09:07 PM
areyouasian's Avatar
yes and no. if you do a little rewiring to convert your motor to obd1 then it will but if not, its a semi obd2 to obd1 conversion.
Old Sep 7, 2002 | 08:34 PM
Smashback's Avatar
Default Re: chipped p28 in 00' EX (areyouasian)
I don't know what these guys are talking about, but if you use a P28, from a pre-96 car, it's ODB-1 which means your car will be OBD-1 and will also mean you are no longer street legal.
If they said it includes and adapter harness then no re-wiring is necessary.
Old Sep 9, 2002 | 09:05 AM
SlowD's Avatar
Default Re: chipped p28 in 00' EX (mplex2000)
No longer street legal? what if my cam gear is advanced or retarded? is that street legal? As long as I pass emissions, I will be happy. I can take the OBD1 out and put back in the OBD2 for the test.
chaos304k
Apr 10, 2019 08:30 PM
Vcastro
Mar 8, 2007 01:41 PM
JDM00SI
Oct 31, 2005 01:54 PM
CRXVtecTX
Mar 14, 2005 06:37 PM
weraider30
Dec 17, 2004 09:45 AM
