Best Way to Calibrate Speedometer in JDM Cluster
Old Jan 18, 2010 | 11:02 PM
vanny_david's Avatar
Default Best Way to Calibrate Speedometer in JDM Cluster
I took the speedometer apart ( including the needle)
When I calibrate the needle, I started the car (car was not moving; speed = 0km/h ) and then put the needle back on at 0km/h position
but that way doesn't work..the speedometer is reading the speed very high ( actual speed = 30km/h, but read 50-60km/hr )
Do you guys have any other method that can calibrate the speedometer correctly?
Thanks x 9999
Old Aug 10, 2011 | 04:20 AM
b2thao2thab's Avatar
Default Re: Best Way to Calibrate Speedometer in JDM Cluster
I know this is an OLD post, but this is how it is done
In any Eg based model civic. the best and most accurate way to recalibrate your cluster once needles have been removed is to do this
1. you need a navigation unit
2. drive a sustained speed in final gear (the faster you go, the more accurate you will be)
3. take note of your rpm for that given speed. (example: 120Kmh, 5th gear, XXXX RPMS)
- this is where the GPS come into play. Make sure you record speed from the GPS and
NOT THE CLUSTER in question of needing to be calibrated
4. jack front of car in the air
5. install cluster needing to be calibrated with speedometer needle OFF
6. Reach the RPMS which you noted in step three while in 5th gear
7. Install needle on speedometer at noted KMH/MPH in step 3
8. take for a test drive and test speed with GPS
Remember the faster you go, the more accurate the speedometer will be throughout the entire gauge.
I hope these instructions were simple enough to understand and good luck with your calibration
KILLAB17VTEC
Nov 7, 2008 07:55 PM
Phil_SiR
Jan 30, 2007 07:21 AM
HULKHATCH10
15
Jul 12, 2005 09:27 PM
mc
Apr 19, 2004 07:58 PM
explosive
Oct 21, 2003 10:14 AM
