Kicker 700.5 (5 channel amp) - Evansville, IN
Old Jan 18, 2010 | 06:47 AM
jwm1986's Avatar
Default Kicker ZX700.5 (5 channel amp) - Evansville, IN
$275
This has just been sitting around for a while.. Needs to go. It's a 5 channel amp and will power your door/rear deck speakers as well as a sub.
That will include a 9 conductor cable for connecting the speaker leads from behind radio to amp + a turn on lead, and 3 RCA pairs. Everything you need except for the power cable and ground in most cases.
Here are the specs copied and pasted from Kickers website.
Model ZX700.5
Power (watts/channel) 2 Ohm Stereo 85 x 4
Power (watts/channel) 4 Ohm Bridged Mono 165 x 2
Class D Power (watts) 2 Ohm Mono 420
Remote Bass Control Yes
Length (in.,cm) 20, 50.7
Height (in.,cm) 2-1/8, 5.4
Depth (in.,cm) 9-5/8, 24.4
Frequency Response 20Hz-20kHz, +0,-1dB
Input Sensitivity (High Level) 250mV-10V
Input Sensitivity (Low Level) 125mV-5V
Signal-to-Noise Ratio >95dB, a-weighted, re: rated power
Active Crossover full-range 12dB/octave, variable 50Hz-200Hz, selectable high or all pass; sub channel subsonic filter 24dB/octave fixed at 25Hz
KICKEQ Boost Variable to +18dB, centered at 40Hz, sub channel only
Differential RCA inputs eliminates unwanted system noise
Automatic Turn-On Modes +12V (Remote) - preferred method; uses the remote turn-on lead from source unit; DC Offset - detects surge from hi-level speaker outputs after source unit is turned on; Audio (Signal Sense) - detects audio signal from source unit
Old Jan 26, 2010 | 08:58 AM
jwm1986's Avatar
Default Re: Kicker 700.5 (5 channel amp) - Evansville, IN
Bump
Old Feb 5, 2010 | 08:07 AM
jwm1986's Avatar
SOLD
jwm1986
Feb 5, 2010 08:07 AM
chasingamy
Audio / Security / Video
Mar 5, 2004 06:57 AM
Liquidgsr
Oct 26, 2002 10:31 PM
GoLowDrew
May 31, 2001 07:48 AM
