Motor hesitates at 1500-2000RPM...what gives?
Old Sep 4, 2002 | 05:33 PM
gsrvx's Avatar
New User
Default Motor hesitates at 1500-2000RPM...what gives?
Just yesterday, I noticed if I floor it @ 1500-2000RPM...the motor hesitates then feels fine. What could it be? Replaced the rotor and that wasn't it. I just bought new plug wires and spark plugs.
-Rod
Old Sep 4, 2002 | 05:57 PM
SlowD's Avatar
Default Re: Motor hesitates at 1500-2000RPM...what gives? (RK)
Yeah my car does that too... when Im in 5th gear. j/k. Ah here's what I'd check:
spark plugs may be fouled, fuel system may be clogged (change fuel filter), the ignition timing may be incorrect, you may also have an air leak on/around the intake manifold. You may even have low, or uneven compression. I dont know. Just my .02
Old Sep 4, 2002 | 06:38 PM
splitime's Avatar
I had something similar with my VX, didnt note the rpms though. I threw some fuel injector cleaner into my next tank of 93 gas, helped a good amount. I didnt do it, but my friend also suggested spraying some throttle body cleaner into the TB.
Old Sep 5, 2002 | 06:27 PM
gsrvx's Avatar
New User
Default Re: Motor hesitates at 1500-2000RPM...what gives? (splitime)
changed the plug wires and spark plugs...problem gone. I replaced the spark plugs with bosch platinums...smell like they run really hot.
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
MyEfSi2Slow
Sep 28, 2008 04:35 PM
AlphaKennyWun
Feb 2, 2008 02:16 PM
QTKEG6
Jun 23, 2002 10:14 PM
