Chiped ECU or Stock ECU????
Old Jan 17, 2010 | 03:23 PM
rocko5845's Avatar
Default Chiped ECU or Stock ECU????
I have to drive almost 200 miles to get to my tuner. I tried running my setup with the chiped ECU in my car and have had nothing but trouble with the performance and the plugs. The chip I have is just a basemap. Would I be better off running the OEM ECU to get to the tuner, or should I run the chiped ECU?
1992 Honda Civic Dx 1.5L SOHC MT D15B7 Non-Vtec
PO6 Chipped ECU (just have basemap)
440cc Injectors (Lucas)
Ebay Modified Intake manifold (70% more volume than stock intake)
2.5in Exhaust system
Fully Rebuilt Head
Vitara Turbo Pistons 8:1 compression (not 9:1)
Custom Downpipe
T3/T4 Turbocharger
Compressor Specs :
3" Compressor Inlet
3.000" or 76.20mm Major
1.988" or 50.50mm Minor
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
Turbine .64 A.R.
Turbine 76 Trim
2.560 " or 65.04mm Major
2.204 " or 56.00mm Minor
Manual Turbo Boost controller
38mm External Turbo Wastegate (custom dump pipe)
Turbo Sequential Blow Off Valve (It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure)
28"x7"x2.5" Front Mount Intercooler/2.5in piping
Adjustable FPR 0-140psi (going to run 38psi to start)
Stock Fuel pump (31-38psi with regulator vacuum attached and 40-47psi without regulator vacuum
Braided Oil Feed & Return Lines
Oil Catch Can
90amp Alternator
10.2mm spark plug wires
NGKBKR7E-11 Plugs (2steps colder) gapped-.026
Adjustable cam gear (set at stock)
58mm throttle body (stock)
Yellow top battery
All sensors are in OEM and working condition and have not been modified in any way.
Old Jan 17, 2010 | 04:17 PM
HRTuning's Avatar
Default Re: Chiped ECU or Stock ECU????
Seeing as you have bigger injectors, the stock ECU is not an option.
If you want to use the stock ecu, put stock injectors back in and don't boost, or disconnect the charge pipe and don't get on it, you'll be able to get to your tuner that way.
Old Jan 17, 2010 | 04:36 PM
rocko5845's Avatar
thanks a lot.
Old Jan 17, 2010 | 04:48 PM
HRTuning's Avatar
No prob
Old Jan 18, 2010 | 05:32 AM
rocko5845's Avatar
Can anyone tell me if the chip in the link below is better than my basemap? I would like to try it out but I want some opinions.
http://cgi.ebay.com/ebaymotors/p06-c...item2c52070a70
Old Jan 18, 2010 | 07:35 AM
HRTuning's Avatar
No, get it from phearable.net
Lil_Jon
Sep 28, 2011 12:06 PM
rocko5845
Jan 16, 2010 06:45 PM
rocko5845
Jan 13, 2010 11:19 AM
rocko5845
13
Jan 13, 2010 10:03 AM
Turbo_y8
Jan 15, 2006 10:19 PM
