sway bar question (Picture included)
i finally got around to installing my CTR 22mm swaybar and ASR bar on my 2000 civic.....after getting everything bolted on and whatnot, i noticed my endlinks arent very perpendicular to the control arms. i figured this was most likely from being pretty low. i think i may have installed it upside down though.
could someone let me know if this is the case? if installed the right way, will it cause the endlinks to be more perpendicular?
how does it look ok? the endlinks arent at all perpendicular to the LCA's. and like i said im pretty sure the bar is upside down. does anyone else know?
hmmm, yea now that i think about it i have seen some with bars mocked up that way. Well how do i get the endlinks more perpendicular? It's almost as if the bar is too short. I know thats not the problem though, its an OEM honda bar.
Mines the same way. I think its because the bar was designed for a higher ride height. Ive been driving like that for probably 2 years with no issues. Stock Si endlinks.
