CEL issues, light but cant get a code
Old Sep 4, 2002 | 04:38 PM
splitime's Avatar
Default CEL issues, light but cant get a code
I'm almost positive i found the jumper location to get the CEL to flash the problem code. After jumping it though the CEL just stays lit, no blinking or anything, then it goes out if i pull the jumper. Once i start the car up though the CEL is back. I have a 92 civic VX, just completed(almost) a mini-me. Put a p28 ecu into it and did the engine work. How can i get the code to read out? I dont want to drive the car yet, the head sounds like a tap dance show atm, needs to be adjusted i believe.
Old Sep 5, 2002 | 05:50 AM
splitime's Avatar
Default Re: CEL issues, light but cant get a code (splitime)
bump
Old Sep 5, 2002 | 10:32 AM
T817's Avatar
I believe your car has to be running when you jump the jumper.
Old Sep 5, 2002 | 09:10 PM
Kamin's Avatar
with the broken ecu does the engine rev limit at like 6000?
it might be a bum ECU.
Old Sep 6, 2002 | 09:53 AM
splitime's Avatar
Default Re: CEL issues, light but cant get a code (KAMiN)
Need to do a valve adjustment and timing adjustment before i'm going to rev it, should happen next day or so. After that i'll check on the ECU and rpm limit, am praying it isnt the ecu
Old Sep 6, 2002 | 10:21 AM
dogpile5's Avatar
25 Year Member
one time i had the same problem and it was becuase the harness for the ecu wasn't securely plugged in. that prob isn't the case here, but worth a shot
92DAB16A
Sep 14, 2012 07:14 PM
jesiaczek
Jan 26, 2012 03:31 PM
1sikhatch
Jan 31, 2010 09:06 AM
Brewer
Jul 7, 2004 01:49 PM
4drGSR
Feb 23, 2002 10:53 PM
