what did i do wrong
Old Jan 15, 2010 | 04:53 PM
mr1320's Avatar
Default what did i do wrong
I have no power bearly moves.
list.
b18b
ported non vtec head
404 cams with springs and gears
msd 6al cap and coil
walborro 255
blox mani and skunk tb
dsm 450ss with resistor box
gsr tranny obx lsd
please help.
thanks.
Old Jan 15, 2010 | 05:02 PM
b20vtek's Avatar
Default Re: what did i do wrong
more details will help like
did you just put the motor together? if not
was the car running fine before you did whatever you did etc
Old Jan 15, 2010 | 05:15 PM
mr1320's Avatar
I did not have the cams msd or mani tb.
it sat for 3years and the pump went bad so i swaped it to my other 255.
idles fine lopes crazy but fine.
ecu is throwing a straight on when just key on but 14 when running.
Old Jan 15, 2010 | 05:16 PM
alterdcreations's Avatar
tune it of blow it
flesh199's Avatar
timing belt off by a tooth.Run on 3 cylinder.Low compression?
Old Jan 15, 2010 | 05:21 PM
mr1320's Avatar
will it idle but not move if its not tuned properly.
I just have the old ubberdata tune from before the cams.
Old Jan 15, 2010 | 05:26 PM
mr1320's Avatar
are these crower 404s built on a diferent center line.
Old Jan 15, 2010 | 06:32 PM
mr1320's Avatar
what do I need for neptune
Old Jan 15, 2010 | 07:45 PM
2.0L_of_fun's Avatar
Get it tuned by somebody who know what he's doing. 404's are suposed to lope when tuned so it's normal than it lope agressively when untuned. But get it tuned or you will blow away what you've juste invested.
Old Jan 16, 2010 | 05:36 AM
mr1320's Avatar
I know its supose to lope at idle with 404s but it should still be able to drive just not well without the tune. I am not trying to go for a cruise or nothing just move it in the drive way. its the same with ls1"s and others i have built they atleast have alittle power before the tune.
Old Jan 16, 2010 | 07:23 AM
flesh199's Avatar
We dont even know if you are at tdc right now...No spec no answer
Old Jan 16, 2010 | 01:20 PM
88Hatchy's Avatar
According to who?
Old Jan 16, 2010 | 07:48 PM
TheShodan's Avatar
Moderator
list.
b18b
walborro 255
gsr tranny obx lsd
please help.
thanks.
Don't see a tune or management to work those DSM 450cc. #1 problem right there.
Old Jan 16, 2010 | 08:21 PM
mr1320's Avatar
I was working on the tune and cam timing today. works better.
I will order my neptune this week.
thanks everybody, God bless
Old Jan 17, 2010 | 08:52 AM
Slow_import's Avatar
agreed, throw some oem injector's in that until you are ready to tune. right now your probably flooding the cylinders.
Old Jan 17, 2010 | 09:57 AM
Natural Aspirations's Avatar
PM me and I can send you something to get you up and running
noobshifter
Engine Management and Tuning
16
Jun 9, 2014 07:38 PM
kimbler99
Dec 25, 2013 06:53 PM
e36m3
May 12, 2009 07:32 PM
DrftJnkies
Aug 6, 2008 12:24 PM
bertsb18hatch
Dec 14, 2007 11:41 PM
