Half shaft is jammed in the intermediate shaft
Im trying to remove the inner joint on the half shaft from the intermediate shaft or support shaft. I tried to get it out with a pry bar for 6 hours still wont move.
It's a 94 Accord LX
It's a 94 Accord LX
Easiest way...
Remove the three 14mm bolts that holds the intermediate shaft in and pull the entire assembly out. Put the assembly in a vise and use an air hammer to drive your axle off. You could also use a regular hammer if you want, but that'll take longer.
Thanks man.
biassj
May 16, 2003 03:57 AM
