Suspension & Brakes Theory, alignment, spring rates....
CPL EJ8 Civic Suspension Upgrades - Installing Energy Bushing, Ball Joints...[NO-56k]
Old Jan 15, 2010 | 09:54 AM
CplNet's Avatar
Icon6 CPL Civic: DIY Poly Bushing, Ball Joints, Exhaust, etc... [NO-56k]
Hello
here is the ups i'm doing on my suspension for my 99 civic ex ej8...
what i'm doing:
- replacing all bushing by energy black
- replacing the upper ball joint & lower ball joint
- replacing tie rods
- replacing powersteering and driveshaft boots
- new brakes pads, new brake discs
- new exhaust
here is the photos of the progress in the first week of work, hope you enjoy it and help someone with questions about the install
it's posted on my website too, www.nrteam.org/tech/31
i will upgrade this thread as i do more stuff..
now i'm waiting for the new brakes, new arms bolts, new caliper seal set and free time hehe..
greatings from brazil, cpl.
-- update 20/04/2010:
What i did:
All rubber bushing replaced by polyurethane from prothane/energy:
-Front Spring Isolators
-Front Upper Control Arm Bushing
-Front Lower Control Arm Bushing
-Front Sway Bar Bushing
-Front Shock Upper/Lower Bushing
-Rear Spring Isolators
-Rear Uppper Control Arm Bushing
-Rear Lower Control Arm Bushing
-Rear Control Arm Bushing
-Rear Shock Upper/Lower Bushing
-Rear Trailing Arm Bushing
-Tie Rod Boots
-Ball Joints Boots
-Steering box passenger side bushing
Plus:
New Tie Rod Ends
New Front Wheel Hubs
New ball joints (upper/down)
New sway bar end links
New brake rotors
New brake pads
Brake caliper seal kit
Stainless Steel 60mm homemade
OBX Twin Loop Muffer
Old Jan 16, 2010 | 11:40 AM
CplNet's Avatar
Default Re: CPL EJ8 Civic Suspension Upgrades - Installing Energy Bushing, Ball Joints...[NO-
0 replies? that sucks :-( had a hard work to post all those pics..
... i posted this in the wrong forum maybe?
Old Jan 16, 2010 | 11:48 AM
sayyoooon's Avatar
i was actually waiting to see all the end results and feedback on how the car feels now.
Old Jan 16, 2010 | 11:56 AM
STOCK_SOHC_DX's Avatar
Good pics, a lot of the HT'ers don't like poly because they deform over time plus they are lazy to install or don't have the resources to do it themselves. I also liked how you did the other maintenance during your install another thing that commonly over looked.
Old Jan 16, 2010 | 03:50 PM
magohata's Avatar
good job man.
I bought as a kit for my Sedan Civic LX 00, but in red, I hope to have them in my country the 30th of this month, this tutorial will help me a lot with the installation.
very good pictures.
I would like to see photos of the installation for the rear
Old Jan 16, 2010 | 04:04 PM
89civicdx's Avatar
oh you did a good job
Old Jan 16, 2010 | 06:13 PM
kristo's Avatar
Loved
Nice work both on the install and the post here.
Car will feel and ride like a rock.
Old Jan 16, 2010 | 10:53 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
good work,
Old Jan 18, 2010 | 05:47 AM
CplNet's Avatar
hehe.. i will finish just in february... i'm working on the car only at the saturdays now =(
really HTers dont like poly? didnt knew that... and they deform over time? deform how? but that is in a long time right...?
Originally Posted by magohata
good job man.
very good pictures.
nice i'm glad this will help you.. any doubt pm me i'm glad to help.
i'm starting the rear in two weeks.. wait for pics and keep reading this thread.
tkz
Thankz :D hope the handling improov
Originally Posted by ohsnapzafingcu
good work,
thankz
Old Jan 18, 2010 | 09:16 AM
JLCivixHBDX's Avatar
In this picture of the top plate
The exterior bushing is not in good position (upsidedown)
a lot of work for installing ES bushing kit..
Old Jan 18, 2010 | 11:55 AM
I have personally seen 1.5 years but on these boards usually 2-5 years. I'm pretty sure weather conditions have something to do with it.
Old Jan 18, 2010 | 02:36 PM
CplNet's Avatar
hello, thankz a lot for your help..
i was in doubt about this bushing, but i believe it isn't like the stock position.. i tried it.. and the sleeve doesnt fit well... and the format of the poly bushing is a little diff from the stock one too..
take a look at the stock / poly bushing height/format here please:
http://yfrog.com/0aimg0755nj
http://yfrog.com/3uimg0756j
Old Jan 18, 2010 | 02:37 PM
CplNet's Avatar
oh ****, no way! ( really?
it should last at last 3years .. that is the minimum i accept hehe.
where do you live? it's cold ? maybe something with the weather indeed.. but you are in a too hot or too cold area? i'm in brazil.. here's hot.
Old Jan 20, 2010 | 11:47 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
dude.....i just did all this to my EJ right before i put it away!!!
COMPLETE DIFFERENCE!!!
i did some little maitenence things whiel i was under there as well....check it out....here is a link ot my thread i made....
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/more-than-i-expected-doesnt-even-come-close-1-job-turns-into-10-updated-pics-2653817/
check it out!!!
the difference is amazing.....read my thread....let me know if you got a ?'s....
Old Jan 20, 2010 | 06:41 PM
Hawaii, probably hot like Brazil.
Old Jan 21, 2010 | 05:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
There are other issues with poly bushings, too - namely the poly RTA bushings tend to bind whereas rubber, hard rubber, or spherical allows the proper range of suspension motion. Spherical isn't really suited for daily street use, though.
Old Jan 23, 2010 | 05:28 AM
CplNet's Avatar
+photos/progress..
new brake disc rotors, new lca bushing, new lower ball joint and boot
Old Jan 23, 2010 | 06:28 AM
boostatic's Avatar
nice work man..very detailed!!!
Old Feb 2, 2010 | 05:55 AM
CplNet's Avatar
thankz
i'm starting the rear this weekend and will post more pics.
Old Feb 8, 2010 | 04:07 AM
CplNet's Avatar
Update from saturday:
Old Feb 14, 2010 | 12:22 PM
magohata's Avatar
good job man!!
and finally received my bushing kit in red I have completed almost all the front, but still have problems with the rear of the car.
Where can I get the bushing for this part
these are not included in the kit
I could not find on the website of energysuspension.
please help !!!!!
Old Feb 14, 2010 | 11:10 PM
Tyson's Avatar
theres no doubt. this is the wrong way.
Old Feb 14, 2010 | 11:14 PM
92civiceg9gsr's Avatar
I dont think that energy suspension makes rear lower control arm bushings for EK's. But here are Prothane polyurethane rear lower control arm bushings. http://www.summitracing.com/parts/PTP-8-308-BL/
Old Feb 15, 2010 | 04:53 AM
CplNet's Avatar
hummm it's wrong? ok i will reassemble
i invert the upper bushing position
and the lower bushing? same position as upper or oposite to the upper ?
Old Feb 15, 2010 | 04:54 AM
CplNet's Avatar
good job man!!
please help !!!!!
humm im needing it too.... i will research the options and post here but i believe it will be the prothanes.. depeding on the price
