lsv swap when should vtec kick in?
I have a lsv swap b18a block b16 head with gsr ecu (p72) at what rpm should vtec kick in? To me it feels late maybe almost 6 grand. Could it be wrong ecu? Could i use a a p28, get a vtec controller or is my problem bigger or do i not have a problem? Im just looking for some help im new to the lsv swaps i had a b16 swap in my old hatch and vtec popped at like 4,200 rpm's thank you in advance.
The P28 is what you want. VTEC will engage at the ideal 5200 RPM.
The GSR ECU you are using is most likely throwing codes as well because it will be looking for the IAB's which are not there.
The vtec switchover point all depends on your motor, and your tune.... a lot of my friends think that many LSvtec's run perfectly with their vtec point set to 4,500... but, thats not true. My friend has his B20Vtec set to 4300 and i had to have mine set to 5,800 for it to work at its best. It really just depends.
well at 4500 rpm's it sounds like the vtec's popping but dosnt feel like it then around 5800 it pulls hard as hell. At low rpms it fells a little slugish. A friend of mine told me to get a chipped p28 because the p72 (gsr) one is reading sensor's and thats why it feels the way it does at low rpm's and the vtec popping wierd.
I have an ls vtec.. I'm running a b18a block, b18c head (p72 gsr head) with b16 a pistons.. I'm running a custom tune, not just a stock gsr or si tune. you have a custom motor there for a custom tune should be put to use.. Your vtec should crack at whatever your tune is set, do you know if your ecu is virgin? to be honest, and some may argue.. it's better for your vtec to be a smooth cross over... you shouldn't get a HUGE boost in power when vtec kicks in, it should be smooth, that's a good thing. My B17 da integra has a chipped jdm pr3 ecu, vtec cracks low at 4200 rpms and I redline at 8800, but my vtec is super smooth, I can run between 4100 and 4300 and feel no difference, I just hear the vtec crack. The point isn't to gain power, it's to hold your power to redline.
First of all. Like everyone said get it tuned. And no way you will not need a VTEC controller. Get a p28 and ask around for a reputable tuning shop.
B20inDCinLBC
Oct 30, 2006 10:04 AM
