Turbo'ed & Tuned????
Im bout to go have my 92 Civic Tuned, which is now turbo'ed. Are there any certain items I can add to the car, or take with, to make the tune easier and quicker? I planned on taking 2 sets of plugs, but other than that, nothing. I just dont want to travel 250 miles and find out Im not prepared. OUCH!!!!
How satisfactory has your tune been?
Thanks
Thanks
make sure your car is ready is the most important, make sure your ignition and cam timing are good, fresh oil, plugs and wires, valves adjusted, fuel filter, cap and rotor, no oil leaks , no exhaust leaks, no boost leaks, no vacuum leaks, no gas leaks, no cels, have the proper injectors and map sensor for your power goals, proper clutch for you power goals, axles in good condition, tires in good condition. I always take extra plugs with tools to remove and gap them if needed and extra oil to top it off if it needs it.
