compressin numbers after rebuild
Old Jan 14, 2010 | 05:38 PM
rotascircuit's Avatar
Default compressin numbers after rebuild
Hey I got a 95 gsr and did a little rebuild after misshift.
THINGS CHANGED
new rings
used but good condition gsr valves
cyl1=165
cyl2=175
cyl3=180
cyl4=175
Thats after I drove 72 miles on the build.
What do you think???
Old Jan 14, 2010 | 07:20 PM
DC4KiD's Avatar
Default Re: compressin numbers after rebuild
...what did you do as far as the "rebuild" went?
Old Jan 14, 2010 | 07:37 PM
what you mean?
I got new rings and changed out the bent valves and had them seated in
Old Jan 14, 2010 | 08:12 PM
all-mtr-teg's Avatar
Did you have the block inspected by a machinist to see if it needed a hone? Perhaps walls were glazed over and new rings didn't seat well. Your numbers are a bit low, but at least they are pretty close, not the best numbers but still within specs. How did you do the test?
Old Jan 14, 2010 | 08:30 PM
ok we did hone out the block and gave it a new set of cross marks.
I had the car idle for a good 5 min.
put the gauge in and ed the car the throttle wide open. We ed the car till it did not go no more
Old Jan 14, 2010 | 09:28 PM
DC4KiD's Avatar
What about the head work? Did you get the valve faces ground down and the valve seats redone?
Old Jan 15, 2010 | 10:29 AM
yea he used the special stuff to set in the valves
Old Jan 15, 2010 | 10:56 AM
00Red_SiR's Avatar
All Motor Mentor
While honing is important, it's useless if the cylinders are out of round/spec and need to be bored. The piston rings wouldn't have seated in 5 minutes of idling either so that would lower compression. This is not the proper way to seat rings. The valves, assuming they were done right will need to be heat cycled but having a proper valve job done would have been the correct way of re-doing the head.
Old Jan 15, 2010 | 11:26 AM
well I figured if the car ran strong before then it would still run strong....
Old Jan 15, 2010 | 11:30 AM
mavvrik's Avatar
^^^word this not the correct weay to seat rings
Old Jan 15, 2010 | 11:32 AM
Scott_Tucker's Avatar
That is not the proper way to service valves.
Old Jan 15, 2010 | 11:42 AM
well I mean he said he seat them in the way you should
Old Jan 15, 2010 | 12:12 PM
igorka_91's Avatar
We broke his rings in like this. 1st gear-Smash it till 6, let go and let it coast down by itself till 2k rpms. Then second the same till 6 then 3rd the same till 6. Then we went up in the rpm range a lil more and more in every gear.
Old Jan 15, 2010 | 12:22 PM
mar778c's Avatar
Community Builder
Community Influencer
Lol
Check timing and valve lash.
Old Jan 15, 2010 | 10:55 PM
Originally Posted by mar778c
Lol
valve timing is what is going to keep e busy saturday
Eddieem1ef2
Jul 9, 2014 05:10 PM
xxmastermindxx
Dec 8, 2007 10:28 AM
toofast4u752
May 8, 2006 04:32 PM
adictionbass
May 4, 2006 07:39 AM
jerseydevil
Apr 4, 2004 07:29 AM
