how do i get this off????????
Old Sep 4, 2002 | 01:24 PM
Doogie Howser's Avatar
Default how do i get this off????????
i am removing my axel and i know you are suppose to be able to just "pry this part off, but i cant get it. Where should i be trying to pry it and what do you guys use to do it. is there a reason why it would be stuck?
thanks for the help
Old Sep 4, 2002 | 01:30 PM
bryan305's Avatar
Default Re: how do i get this off???????? (mlambrecht)
just grab the axle and give it a good tug...should pop right out.
Old Sep 4, 2002 | 01:37 PM
sgT's Avatar
sgT
Default Re: how do i get this off???????? (bryan305)
and pull apart the joint which would force you to disassemble and reassemble the joint.
But since there is no axle there, it probably wont matter.
Instead, hit the axle with a hammer to push it off the intermediate shaft.
Old Sep 4, 2002 | 01:59 PM
boosted spoon's Avatar
Default Re: how do i get this off???????? (sgT)
<U> Instead, hit the axle with a hammer to push it off the intermediate shaft </U>
Old Sep 4, 2002 | 03:23 PM
hondafrk's Avatar
Default Re: how do i get this off???????? (boosted spoon)
daym thats a greasy little bastard, You can try to pry it off with a big screwdriver or a pry bar.
Old Sep 4, 2002 | 03:51 PM
Default Re: how do i get this off???????? (hondafrk)
i tried with a pry bar and it wont come out, is there sometihng i could spray on it or other ways to get it out when it is this stuck?
Old Sep 4, 2002 | 04:16 PM
salbaje's Avatar
if you want get a socket big enough to fit in there and hammer it with the round end against the gap ive done that many times and works everytime. use a bigger hammer not just a regular one
Old Sep 4, 2002 | 04:37 PM
Default Re: how do i get this off???????? (salbaje)
that didnt get it off, should i try spraying somethig like liquid wrentch, or are there any other ideas.... god this is pissing me off!
Old Sep 4, 2002 | 04:59 PM
purpl7duece's Avatar
get the torch out.lol Did you take the balljoint off?
Old Sep 4, 2002 | 05:41 PM
baonest's Avatar
Default Re: how do i get this off???????? (purpl7duece)
getting it out from the trans is what u gotta do... stick a pry bar where u can put it and just pry it outa the trans.. works everytime, just need to put a little elbow grease(damn that sounded cheesy) on it
Old Sep 4, 2002 | 06:10 PM
Default Re: how do i get this off???????? (baonest)
so you saying i should take the whole drive shaft out of the tranny? because on the driveer side the axel goes to another shaft then to the tranny
Old Sep 4, 2002 | 06:30 PM
Malice's Avatar
New User
Old Sep 4, 2002 | 06:59 PM
Default Re: how do i get this off???????? (MaliceGSR)
i got it off now the new one wont go back on, are you suppose to always replace that stoper ring because i think that is wat is stoping it from going back on
Old Sep 4, 2002 | 07:51 PM
InevitableRace's Avatar
hahhahahahahahhahahha Good job
Old Sep 4, 2002 | 08:04 PM
Default Re: how do i get this off???????? (allmotrb18c1)
i have finished putting the axel in, now i need to put 2 quarts of tranny fluid in, im wondering what you guys use to put in the fluid, do you use some kind of pump?
Old Sep 4, 2002 | 10:37 PM
tinkerbell's Avatar
i run a 3 foot garden hose with a funnel in the top down to the fill hole and pour from above hte engine...
make sure hte car is level when you are doing hte refill...
HTH,
t..
Old Sep 5, 2002 | 06:44 PM
baonest's Avatar
Default Re: how do i get this off???????? (tinkerbell)
howd u finally get it off...
WhiteTrashedDA9
Feb 16, 2013 09:30 PM
Hoppa
Dec 5, 2006 08:51 AM
huepowered
Mar 27, 2006 12:33 PM
Boosthead
Jul 12, 2005 12:57 PM
Boosthead
Jul 10, 2005 10:32 AM
