New to the F22b Sohc and trying to boost it
Old Jan 12, 2010 | 03:08 PM
jaytwou2's Avatar
Default New to the F22b Sohc and trying to boost it
Well whats up guys i just bought my cd5 and im doing the auto to 5 speed swap and also going to be building the F22 for boost and Nos i wanted to know where you guys out there are going tog get your parts like valves pistons and what you guys are doing about the bottom end of the motor. Thanks for the help guys!
Old Jan 13, 2010 | 10:43 AM
xero_xero's Avatar
Default Re: New to the F22b Sohc and trying to boost it
here is the catalog for pistons, rotating assembly, and rods
Weisco Acura/Honda
Here is the tsi complete kit. it is a little pricey, and you can build your own from parts list, just a bit more complicated. used this kit on an accord (96) and an eg civic with an h swap.
TSI complete turbo Kit
Old Jan 13, 2010 | 10:45 AM
xero_xero's Avatar
as far as a nitrous setup, zex is a plug and play kit. it wires into your tps sensor, and you activate it via throttle and ecu vs button so you can not activate the setup early, grab a second oem intake and drill for near direct port injection.
Old Jan 13, 2010 | 10:48 AM
turbosyndicate's Avatar
Trust me on this one!!!...as a former 92 Accord owner.....do the h22 swap. FAARRR more reliable, plenty fast and will come with manual tranny. Cost will be the same if not cheaper in the long run for the same power.
Old Jan 13, 2010 | 12:05 PM
jaytwou2's Avatar
You see what im trying to get at is staying sohc and putting the dohc to shame i know its gonna be costly but theres no cars out in my area that i know of running a F setup sohc and having power so i wanna stay sohc and boost it and have the nitrous just in case!
Old Jan 13, 2010 | 12:11 PM
Brad_and_the_acc's Avatar
"You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake!"
FAQ`s
Old Jan 13, 2010 | 01:31 PM
bigsnorlax's Avatar
who says a turbo setup isnt reliable? With a good tune and low boost (~10 psi) you would be making more than a stock h22 any day..
Old Jan 13, 2010 | 04:26 PM
littlejon's Avatar
OP- I like your idea. Don't be persuaded by anyone. :-D
Morasso
Jun 12, 2008 06:55 PM
Jaskula1
11
Jan 18, 2004 10:29 PM
TegBen
Sep 14, 2003 11:35 PM
turbofasteg
Apr 14, 2002 05:43 PM
