help oil leak from??
Old Jan 12, 2010 | 08:09 AM
djteggy99's Avatar
Default help oil leak from??
ok so after my rebuild on my gsr im getting a oil leak from under and i dont know where its coming from. Ive searched that if its the rear main seal it would be leaking onto where the tranny and block is but my leak isnt coming to that side is getting onto the drivers side. It would get inside my driver side rim and fender walls, could it be the oil pan gasket? ive lifted up the car and let it run but i still dont see were its coming from.
Old Jan 12, 2010 | 10:12 AM
mavvrik's Avatar
Default Re: help oil leak from??
Depending on how long it's been leaking, it's either gonna be extremely easy to find, or a bit of a challange. Look harder, and if you still can't find it, i reccomend putting some dye in your engine, give it a day ot two, and check where the dye is coming from
ZekeComa
Jan 21, 2013 04:00 PM
95LXDRIVER
Dec 1, 2005 10:35 AM
jansenrw
May 18, 2004 12:05 AM
Civic_Type R
15
Sep 28, 2003 06:44 PM
Ideal
Apr 8, 2003 05:29 AM
