Sun Hyper Ground Wires
The new Hyper Ground System is the safe and reliable tuning system that provides a low resistance ground path. A better ground gives more Torque,better Mileage, better Response, and better Starting Ability.
Hyper Ground System is the best performing grounding system available!
Sun Auto is the only company authorized to provide high performance grounding system as OEM optional equipment.
This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
View applications and prices: Sun Hyper Ground Wires
