Can a grounding system.....
Old Mar 7, 2003 | 12:43 PM
MooreBoost's Avatar
Default Can a grounding system.....
be grounded to the chasis? I thought I saw some say that it connects directly to the negative post on the batt. But the connectors for my sub wires go ontop of the posts, so could I ground the engine to the chasis with one of these kits? And would it still have the normal results?
gmoore
Old Mar 7, 2003 | 12:47 PM
ragejed's Avatar
Default Re: Can a grounding system..... (gmoore379)
Ground to the chassis if you must. The neg terminal connects to teh chassis. Just more work for the current to flow tho.
Old Mar 7, 2003 | 12:49 PM
MooreBoost's Avatar
Default Re: Can a grounding system..... (ragejed)
Do you think its even worth it if I have to ground to the chassis?
gmoore
Old Mar 7, 2003 | 02:04 PM
ragejed's Avatar
I honestly wouldnt know the difference. But I know when I do mine..I am going to the neg terminal
Why dont you just get a bigger clamp on the terminal?
Old Mar 7, 2003 | 02:45 PM
jdmotorsports's Avatar
your chassis is your ground. you do know that the flow of electricity id negative to positive? the better a ground you have the better flow you'll get. thats why when you buy amp kits they give you a long + and a short - wire because your supposed to ground it to chassis.
delta25
Audio / Security / Video
Nov 24, 2010 12:56 AM
RedlineMotive
Jan 23, 2010 07:51 AM
RedlineMotive
28
Sep 22, 2009 08:45 PM
90Rexx
Aug 25, 2009 12:00 PM
GoLowDrew
Jul 17, 2006 11:05 PM
