vtec controller or ecu tuning? differences?
Old Jan 11, 2010 | 12:46 PM
Funanin's Avatar
Icon2 vtec controller or ecu tuning? differences?
hi fellas- I just have a quick question. If I have a chipped ecu (P28) and I use Crome to change my vtec enabling rpm, what is the difference between doing that and spending the $300+ on an aftermarket vtec controller? Dont they do the exact same thing? Thanks
Old Jan 11, 2010 | 01:49 PM
90_EX_Civic's Avatar
Default Re: vtec controller or ecu tuning? differences?
a vtec controller does that, control vtec.
when you get it chipped, even a base tune/map it adjust your timing also.
vtec needs to be tuned with your timing, or else you won't get the most benefit from it.
Old Jan 11, 2010 | 01:52 PM
mrharmonic's Avatar
also you can control your fuel and other thinkg lol im a little brain dead and i have one lol but there great but when you start wanting hiering numbers your gona need the s100 and throw out the vtec controler as you can control everything with a computer
Old Jan 11, 2010 | 01:53 PM
Sliced Beard's Avatar
VAFC controllers are not very accurate. ECU tuning is way more accurate and you will see the best results if done with aid of an experienced tuner on a dyno.
Old Jan 11, 2010 | 04:07 PM
MonkeyMagic's Avatar
dont be a goon, choose a tune. ...although, on a z6 auto, i don't think it really matters.
and btw lowering the vtec crossover point has absolutely zero positive benefits.
Old Jan 11, 2010 | 05:44 PM
Funanin's Avatar
Icon3 Re: vtec controller or ecu tuning? differences?
I dissagree- I am now boosted with 7 psi intercooled and I DEFINITLY feel a BIG difference when I turned vtec on earlier as the boost can now get into the cylinders more efficiently (per the high and more aggressive cam profile of the vtec)
Old Jan 11, 2010 | 08:15 PM
That is because you are boosted ya dope :facepalm:
Old Jan 11, 2010 | 08:31 PM
MHDesigns's Avatar
Bingo. Search google for why and you will find a writeup on exactly why it does not do a damn thing unless you have aftermarket cams(and a proper tune as well). Vtec is meant to hit at one point to pick up the slack from the lower lobes. The higher lobes are for high rpm only and will not benefit at all by using during low rpms. This is the reason why there is a vtec changeover in the first place. I'm sure someone else can explain this a little better.
Old Jan 12, 2010 | 08:59 AM
Funanin's Avatar
OK well getting back to the original question then, by using crome and my ecu to tune my car I dont need to ever get a vtec controller then correct because the ecu does the same thing and more correct?
Old Jan 12, 2010 | 10:34 AM
Relic1's Avatar
correct.
the ECU does a much much better job of controlling VTEC than a VTEC controller could ever do.
Old Jan 12, 2010 | 10:37 AM
owneyboy's Avatar
Originally Posted by Relic1
correct.
+1 instead of paying $300 on a stupid gadget that doesnt work get it tuned. a vtec controler just makes vtec work at a different time but when i was tuning a friends car hes stupid vtec controller made it a pain and didnt help. the vtec controller does not control -AFR- it does not change to the HIGH CAM maps where it adds fuel and timing to make vtec function like it should. vtec controllers will jus make the noise so pretty much bog out your car.
Old Jan 12, 2010 | 11:31 AM
Funanin's Avatar
ok thats what i figured- I have mine chipped and I use crome now, just reassuring its the best way. Thanks guys
blacktibby07
Jun 8, 2011 07:11 AM
ExCiViChYbRiD
Oct 20, 2007 07:14 AM
yeah_its_boosted
Nov 2, 2005 09:34 PM
95blackegcoupe
Jun 29, 2005 05:04 PM
Eibach95Civic
Jun 17, 2003 10:59 AM
