Classic Hondas All Pre-1988 Hondas.
1987 civic 1.5 SOHC Automatic carburated not moving
Old Jan 11, 2010 | 10:39 AM
Doug_I's Avatar
Default 1987 civic 1.5 SOHC Automatic carburated not moving
Hi everyone
Any help or suggestions would be very much appreciated.
This is actually an extension of my last post.
Just finished putting this car back together last night.
I was going to drive to the gas station and be done with this,,,but
The car started and ran beautiful. I shut it off, and when I restarted it it stumbled like it was missing. when I put it in reverse the rpms would drop and stall. If I play with the gas pedal it will smooth out around 750 rpm, and seem to run normal.
We have 3 cars and mine is the only one running.
I am getting to the point of just setting it on fire.
Below is a list of what I have done:
carb rebuilt, cap rotor and wires.
cam seal
thermostat
The keyway broke on the cam sprocket and turned just enough to bend all the exhaust valves.
New valves
Had a machine shop check for cracks
Head Gasket set....
water pump and timing belt
new alt and belt
Replace the high pressure line
rear wheel cyl
4 tires
Radiolotek
14
Jul 31, 2013 02:20 AM
usapooky
Oct 8, 2009 06:03 PM
NathanMorris
Mar 20, 2007 08:58 PM
newbster
Oct 13, 2006 09:43 PM
cmrvi1
Aug 27, 2004 08:56 PM
