95 integra sedan b18b1 problems
Old Jan 11, 2010 | 01:52 AM
lao-boy503's Avatar
Icon6 95 integra sedan b18b1 problems
I need help to solve a problem? I was driving home on new years day then all the sudden my car started to jerk and shut down on me . So as I pulled over it shut down.everything works in my car besides My windows and windsheild whippers. Can someone help me find thethe problem oyeah the car turns over but won't start thanks for looking
Old Jan 11, 2010 | 01:58 AM
fasthatch95's Avatar
Default Re: 95 integra sedan b18b1 problems
do your basics! check 4 spark and fuel.
Old Jan 11, 2010 | 02:06 AM
lao-boy503's Avatar
I just got a tune up 3 weeks ago but I checked everything and it all looks good
Old Jan 11, 2010 | 02:59 AM
Targa250R's Avatar
be professional
Did you physically check for sparks at the plugs? What did you see?
Old Jan 11, 2010 | 03:44 PM
lao-boy503's Avatar
well my spark plugs aint sparkin but i changed the ignition and it still wont spark help me ppl
Old Jan 12, 2010 | 08:06 AM
Ign cotrol module and ur coil other than a fuse would do this to your honda, cap and rotor if itz that bad! Dont forget that the reception spring between ur ign coil and distirbuter cap. Itz probably a simple distributor internal problem. if u changed the ign module inside of distributor try a new coil.
Old Jan 12, 2010 | 08:15 AM
Targa250R's Avatar
be professional
How did you check for spark? Did you hold the ground electrode against a piece of bare metal in the engine bay while someone else cranked the engine?
You changed the ignition what? Ignition coil? Ignition control module (a.k.a. ignitor)?
Old Jan 13, 2010 | 12:14 AM
lao-boy503's Avatar
i changed the ignitor and i held the electrode against a piece or bare metal and no sparks so i changed the fuel pump today and still wont start just turns over i checked the spark plugs and spark plugs wire on top of that
Old Jan 13, 2010 | 04:38 AM
Targa250R's Avatar
be professional
If you're still not getting spark, why would you change the fuel pump? Did the old fuel pump run for a few seconds after you turned the key on?
If you replaced the ignitor and still have no sparks, then replace the ignition coil. The coil is actually a more common failure point than the ignitor.
grandtheftlunchbox
Oct 12, 2008 05:51 PM
JasonST
May 31, 2006 09:39 PM
vangc6780
Aug 10, 2005 08:40 AM
BadBeck
Dec 11, 2003 05:59 PM
