Function&Form Full Coilovers DC,DB
Old Jan 10, 2010 | 10:17 PM
nuckingfuts's Avatar
Default Function&Form Full Coilovers DC,DB
Lightly used (7,000 miles) Function&Form type II fully adjustable coilovers. These will fit most integras. Asking $500.
The new and improved Type II coil-over is a complete coil-over with a fully threaded shock body. Through extensive research and development, Function & Form Autolife has enhanced an already largely successful product. While the previous design was very popular, the new Type II coil-over has added features that serious car enthusiasts will find to be irreplaceable.
Added Features:
•32 levels of dampening adjustments
•dampening adjustments made with a **** that clicks at each level setting
•steel construction of the lower mounts for maximum strength
•adjustable ride height from bottom mount allowing driver to retain full shock travel while -- lowering the car
•special oil lubrication able to withstand weather conditions from -40C to 200C
•dual tube shock design for maximum ride comfort
•wireless dampening adjuster (Wi-damp) available for most applications
•43 mm Double wishbone piston
Old Jan 10, 2010 | 11:31 PM
flatblack-h22's Avatar
Default Re: Function&Form Full Coilovers DC,DB
bump 4 u
let me check my moniessss
Old Jan 11, 2010 | 04:54 AM
ph3ar's Avatar
Is that a pic of your actual shocks, or the manufacturers pic? Have any idea what kind of spring rates these are? Thanks.
Edit: Found the spring rate specs on the website. Theyre 12k front, 8k rear.
Old Jan 11, 2010 | 11:05 AM
That is a pic from the manufacture, they are presently still on the car (which is in storage). The only pic I have of them was taken when they were fresh out of the box before installation (just like the pic above)^^^^
Old Jan 11, 2010 | 11:12 AM
ph3ar's Avatar
Awesome. How did you like them? I have a sedan, and am looking for something a little stiffer than stock.
Old Jan 11, 2010 | 01:52 PM
It rode much nicer than my old kyb agx and eibach spring setup! Can go very very low also. I had them on my 4 dr as you can see.
Old Jan 11, 2010 | 01:55 PM
ph3ar's Avatar
Wow, what a picture. Looks about like my sedan. I dig the ride height. They didnt feel too stiff for daily driving? That picture probably just sold those coilovers. lol
Old Jan 11, 2010 | 01:56 PM
KPPPowa's Avatar
bump for homie
Old Jan 11, 2010 | 02:18 PM
No, they are quite comfortable. Firmer than stock but not bouncy at all. I did have a little issue in the back but I am fairly confident that it is due to my rear trailing arm bushings being worn out @ 160k+ miles. I had the Skunk2 front upper control arms with adj balljoints and with a proper alignment, 205/50/15, and proper tire pressure this car rode great. You do need the spring rate they typically sell especially if you plan on having passengers in the car. It's well worth it.
Old Jan 11, 2010 | 05:29 PM
carbon fiber coupe's Avatar
should fit eg's too
Old Jan 11, 2010 | 09:03 PM
Yes, they will fit EG's too. Slightly stiffer spring rate but will be okay if you have a B, F, H or K series up front.
Old Jan 11, 2010 | 09:21 PM
dischink_g0tph0's Avatar
would u take in any trades plus cash???
Old Jan 12, 2010 | 01:21 AM
APCXxstovetopxX's Avatar
also interested if you take trade, i have b series turbo stuff, the turbo, manifold, megasquirt ecu, injectors, FPR
Old Jan 12, 2010 | 06:37 AM
mgrcrx's Avatar
pm you need bad
Old Jan 12, 2010 | 04:50 PM
Possible trades for K series stuff only. PM me with all trades and I will consider.
Old Jan 13, 2010 | 01:27 AM
ph3ar's Avatar
Oh ****. My subscription of this thread never emailed me. I'll take the coilovers. Im paid in 3 days, and I can send u fundage via paypal.
Old Jan 14, 2010 | 01:07 PM
hype_R's Avatar
lol
word
Old Jan 15, 2010 | 04:43 AM
ph3ar's Avatar
Word, I got funds. Let me know when I can buy these! They will need to be shipped to 65020! Thanks!
Old Jan 15, 2010 | 06:05 AM
TEG_UR_IT's Avatar
If ph3ar doesn't end up getting these, I'll buy em!
Old Jan 15, 2010 | 07:49 AM
Makdaddynuge's Avatar
what are the spring rates?
Old Jan 25, 2010 | 10:31 PM
ph3ar's Avatar
Bump, still want these, check your pms!
Old Jan 30, 2010 | 12:05 PM
ph3ar's Avatar
Bought these *****! Thanks man!
Old Jan 30, 2010 | 01:14 PM
caseyliffick's Avatar
Damnit! Why didn't I see this before!
JDM_JNKY
Oct 10, 2011 10:52 AM
tom@yoparts.com
13
Oct 10, 2009 07:33 PM
PARADOX_sf
Suspension & Brakes
Sep 25, 2008 07:27 PM
dragonfly2k3
Suspension & Brakes
Aug 26, 2008 12:03 PM
mytoesarecrazy
Honda S2000
Nov 9, 2006 07:25 PM
