What ecu for my B16a2 swap??
if you remember I have the 98 spec RHD ITR. I have been going back and forth on what to do motor wise for some time. I am now in the position where I just need to car drivable. I picked up a complete B16a2 swap from a wrecked 2000 civic SI today with 110k miles on it. I have the RHD harness that came with the caR. I also received the ECU from the 00 SI which I believe to be a P2T ecu.
Will this ECU and Harness work with the car?
If not what do I need to switch these out with or what ELSE do I need to make this work?
Thanks for the help folks!
Steve
Steve
yup you will need the rhp engine harness from your car, and then go plug the ecu into the chasis harness and if it doesnt plug in then you need a jumper harness to make it work or just get a jumper harness with a obd1 ecu, you will need all the integra motor mounts and then the integra timing belt side block mount(i can sell you that as i just had to buy a si one for my 18c)
use the rhd integra harness and an obd2a to obd2b ecu jumper and you should be fine with 99 si ecu. You could also use a 96-98 spec obd2a jdm b16 ecu or a 96-97 del sol VTEC(p30) obd2a usdm ecu without needing a ecu jumper harness. orrr you cauld just use a obd2a to obd1 ecu harness and use an obd1 b16 ecu.
My buddy parts out cars and has all the mounts I need so he says. I was just wondering on the harness/ecu situation. What is the best place to pick up the jumper harness? lookin to spend the least money possible as I plan to do a K20 swap this summer once I have the funds available but I NEED a car to drive for now.
when i bought my shell the 98 spec RHD ITR harness came with the car. i just need a conversion harness for obd2a to obd2b. thanks though.
Still looking for a good place to purchase the conversion harness....
Some one on another forum brought this idea to my attention:
why not just get an ITR ecu so you dont have to spend the money on the harness and then an ITR ecu in the future?
So my question is:
will the P73 ITR ecu work with my 98 JDM db8-R harness/ the car itself/ and the 00 SI swap with out anything else necessary plug and play?
Thanks steve
So my question is:
Thanks steve
So my question is:
Thanks steve
So my question is:
Thanks steve
just get a 98+ B16 JDM ECU, done. $200 bucks for the right ecu, and not have to deal with it.
use the harness that your RHD car has, the only issue you are going to have is plugging up to the air intake temp sensor.
Ignore the crank sensor by the water pump and you should be all set. This is really an easy swap. Don't forget you need integra mounts, not EK mounts.
think im just gonna hunt out a p73 ecu. looks like its gonna run about 175 but hopefully ill be able to sell my p2t ecu that came from the 2000 si.
Sfitz1018
Jun 22, 2017 09:39 AM
