Swap Question 00si into 98dx
Ok, I searched for awhile and could not find the specific answer I am looking for, anyways I want to install my 00si swap into my 98dx hatch. However I want to run an obd1 ecu for tuning capabilities without buying a EMS.
What do I need to do?
Can I use the 00si engine harness and install obd1 injector clips? Or what do I need to use
Please help me out on this.
Thanks
Thanks
First of all you cant use the si harness bc your car is a 98, so you need to use your harness and add in all the vtec sensors, knock, and redo the IACV to 2 wires.
Next get an obd2a-obd1 ecu jumper harness.
Nothing on the motor needs to be changed. The si injectors etc. will be fine.
90Rexx
Sep 15, 2010 10:47 AM
hatchinprogress
10
Jul 13, 2005 04:05 PM
pearl
Jun 11, 2005 04:10 AM
