seafoam for 98 accord.
Old Jan 7, 2010 | 10:44 PM
aznpridelivin2o3_cg5's Avatar
Default seafoam for 98 accord.
sup guys, im thinking about using seafoam for my accord with 127K on it. im also doing an oil change tomoro too. any thoughts/comments on using seafoam ? my friend says not to use it on my car. and also, do i use seafoam before clean oil change ? or after with oil change ? thanks guys.
Old Jan 7, 2010 | 11:28 PM
nus_dogg's Avatar
Default Re: seafoam for 98 accord.
Before clean oil. Seafoam works good.
Old Jan 7, 2010 | 11:46 PM
darkenedsol's Avatar
before
Old Jan 8, 2010 | 07:45 AM
this is also my first time using seafoam on my car too, is that a problem ? i read somewhere that if the car has over 75K and its your first time its not recommended.
Old Jan 8, 2010 | 08:05 AM
Conan's Avatar
I heard the same thing and I think it had to do with it being bad for seals. I suppose if you poured it onto a seal and let it sit for along time maybe. But if you run the car right away it burns off in a couple minutes. I can't see how your seals would be destroyed in 2 minutes. I ran my first can at about 150k miles, and then another one at 200k. One tip I have: Do it ina place where you don't care about leaving a horrendous huge cloud of white smoke, i literally filled the whole Cul-de-sac with white smoke during the day the first time, so the second time, I went to a back road at night.
Old Jan 8, 2010 | 06:24 PM
djkurious's Avatar
Love seafoam and I used it on my Accord @ 280,000 miles! I don't think there is a mileage restriction. Just don't let it sit more than 10 minutes.
Old Jan 8, 2010 | 07:34 PM
dleccord's Avatar
i want a seafoam party!
Old Jan 11, 2010 | 10:03 AM
professorman's Avatar
The reason seafoam is sometimes not recommended for higher mileage cars is because sometimes the crud is actually preventing oil leaks and when you clean them out, the crud is gone, thus leaving the gap to leak oil out of.
Old Jan 14, 2010 | 12:21 PM
slamstrom's Avatar
Since I have never used Seafoam, do you guys/gals use Seafoam to fix an issue or as regular maintenance? If my car is running fine with no issues, should I be using Seaform? Thanks.
Old Jan 14, 2010 | 09:05 PM
I have used it a few times when my mileage was less than 150k. I do not want to use it again since my mileage is now high. I have replaced most of the oil seals in my engine though. I never had any issues with mine. When I replaced my timing belt at 180k miles, one of my seals had just started to leak in the timing belt area, but I had already bought the seal to replace it. I would do it for less than 150k, but probably not more. Its just my personal number. I haven't seen any mileage given out as a limit.
samk1321
Sep 18, 2017 02:44 PM
FinzWake
Mar 8, 2012 08:50 AM
z395civic
Nov 11, 2008 07:32 PM
bonafide
Jun 5, 2007 04:42 PM
hollar at my v6
Jul 23, 2005 05:27 PM
