half radiator in accord
Old 01-14-2010, 02:15 PM
ilikehonda's Avatar
Default half radiator in accord
What does it take to put a half radiator into a 94 accord? i know it has been done and ive searched around but not really found anything.
Old 01-14-2010, 02:23 PM
crx_91si's Avatar
Default Re: half radiator in accord
From what i've seen, i think you have to chop the lower rad mount off, lower and reposition it. I think hood clearance is an issue, or it looks like it from my 98 CL
Old 01-14-2010, 03:54 PM
cstone's Avatar
just out of curiosity why do you want to put a half radiator in? extra clearance in a turbo setup?
Old 01-14-2010, 04:50 PM
alkoholikwun's Avatar
i dont know if you can use a civic rad or not.
Old 01-14-2010, 06:24 PM
GhostAccord's Avatar
The Koyo double core (2") Civic 1/2 rad flows and cools more efficiently then the full sized Accord rad.
If check out my blog or look through my build thread there is more info on how I mounted the Civic 1/2 rad in my CD.
Old 01-14-2010, 06:26 PM
wildstyle554's Avatar
is there a weight advantage with n/a?
Old 01-14-2010, 06:34 PM
2.85Kg (6.5 lb) empty. It also holds more fluid. So I'm not sure that the aluminum is lighter. Anyone have the weight of a stock rad?
Old 01-15-2010, 01:46 AM
ilikehonda's Avatar
ya need more clearance....if i can make it things will go much more smoothly
Old 01-15-2010, 03:21 AM
I have seen people only use 1 bottom mount and use steel strapping on the top mount to hold it in there. I've also seen people using plastic zap straps. I just figured that it would be nice to have it look like it was meant to be that way. Plus I wanted to move it over as far to the passenger side as possible. Room to move
There are no clearance issues with the dual core Koyo Civic 1/2 rad in a CD. Keep the stock lower rad mount height and it will fit.
Eibach95Civic
06-02-2003 08:55 PM
accordfreak
03-10-2003 03:59 AM
Quick Reply: half radiator in accord
